ballisticmike
- Joined
- Mar 11, 2010
- Messages
- 3
- Reaction score
- 0
hello all, nice forum here. oh boy, where do i start.. i am so un-knowledgable but i will keep my question concise. I searched and search and searched on google, very little concise, specific info that i could find on my application. Now even though it looks to me like most of the discussions on your forums are non-car radio based i will ask anyway because i bet alot of you know the answers nonetheless.
In a nutshell- i want to replace the OEM antenna thats on my 2008 F150 with a custom made one.. something much shinier, cooler. and IF POSSIBLE.. will perform close to the same level as the OEM one. I know theres already tons of aftermarket ones on ebay.. billet shorty antenna mostly made with aluminum etc. I dont want and dont like those. I will be making one much much nicer than those.. more artistic, show quality. From stainless steel.
One of the only bits of info i found on google says that 31" is the most common and best compromise for an automotive AM/FM antenna. I measured my Ford antenna, sure enough its 31". Some other bit i read started talking about ratios and 1/4 wave and thats why 31" is best and on and on with technical jargon i dont understand.
So heres my question: my Ford OEM 31" antenna weighs 58.5 grams on my digital scale. I want my custom antenna to be shorter.. probably 15.5". Is it ideal that i maintain the same weight.. 58.5 grams? Is this the way the formula works? In other words my custom antenna with be a larger gauge wire and even though its shorter I can make it keep the same weight as the original , thats not a problem for me to do.
Sidenote: i removed my original antenna and stuck my prototype shorty antenna in, then put the AM tuner on a really weak station and compared reception to OEM antenna. Result.. mine not quite as good but hardly different. Am i way off base in my assumptions here?
