- Joined
- Aug 18, 2018
- Messages
- 4
Hello, all. This is a doozy, and I apologize in advance that I know a little but not a lot -- I've learned in other endeavors that knowing just a bit can be plenty dangerous, and I just want to do the right thing... solid state within reason. The ultimate goal is to be able to distribute decent quality radio traffic to multiple points (maybe 10 tops) in a room that's 60 x 60.
I have a setup where I've got two 996P2s, two 15Xs and three 325P2 handhelds, and I'm in a place where signal strength is a major issue. I have LMR400, ample Cat6 and can get ample audio cable, and I know how to cut and crimp my own stuff. I have a neat collection of BNCs, LMAs, N-types ready to be used on fresh cabling. I've got fast internet, even some wifi. I have 10 repurposed PCs and a handful of SDRs that eventually I'd like to set up and stream privately or put on Broadcastify.
Full disclosure: This is for my employeer, and I'm lucky 'cause I could never, ever afford this gear for my own stuff at home (a Radio Shack-labeled Whistler and a 12-year-old Mac).
The building I'm in is postwar 1950s concrete, steel and brick. It's a bunker on the second floor of a three-story structure with only one window looking to the outside world. That window is 35 feet due east of my desk. Then, I've got the ability to do a cable run to the roof, but that's at least 100 feet of LMR400, of which I have 400 feet.
The problem is that the scanners need to be scattered throughout the room, which is an open-floorplan office with an elevated steel floor for cabling, a la '80s style. Building services has said for a year, "yeah, we'll run your cable through the run to the roof," though at one point they said they wouldn't then they couldn't and then said I needed 400 feet of cable (which I know means the signal is worthless).
OK, to the point: Multiple people need access to the scanners, and it's not feasible to have any more scanners than I've already got. I have a multicoup I bought from ScannerMaster, and before I put sweat and tears into running cable through the room, I want to make sure I've got this thought out well enough to outlast me, and likely this institution.
Ideally, I'd use one of my 800MHz+ Log Spiral Antenna with Suction Mounts from Hex and Flex on the window, some 35 to 50 feet away from where the radios are. Put a preamp on this at the source and then run LMR400 to the multicoupler and then distribute out eight ways.
But then I had another think: The people who use these scanners don't know how to use them -- they are just seeking the audio. Would there be a way I could set up all the scanners in one place (near the window and antenna) and then distribute the AUDIO out to various places around the room using an existing audio amplifier and speaker equipment. Side tangent: In a perfect world, I'd take two weeks off from work and figure out how to fabricate some 3D-plastic built devices that would house a speaker, a scan button and a hold button with a minidisplay using custom-built software that ports the display info similar to what you see in on-screen controllers from the likes of Freescan and ProSCAN. Maybe someday after my wife leaves me...
Now I didn't go out and buy the best and newest scanners that enable web control, mostly because of the limitations the company I work for has put on equipment being on the network (read: super locked down and cyberconscious). I have an external cable modem service that I can hook into that bypasses the network, but again, I'm forced to run cables through the room and I can't make it look like my shack.
Again, I'm a total amateur at all this radio stuff -- I'm very eager to learn and don't have many places besides these forums to do it -- but I'm handy with electrical components and "maker" s---. I don't have a real budget to do this, so I have to get inventive. The ultimate goal is to be able to distribute decent quality radio traffic to multiple points (maybe 10 tops) in a room that's 60 x 60. I want to get the best possible signal with the equipment I have and share it with people. I can't move desks or huddle the team in far corner of the room to make this simple, and I can't tear the place up to run cable 50 different directions (knowing that splitting and distance are weakening my strength).
What do the veteran minds think I should do? Is there a third (or fourth) approach I'm not thinking of?
Thanks, in advance, for not taking me out to the woodshed.
