NOR OPP - One Sided Convo's
MetalCarnage
Ajax Ontario
Hey, wondering if anyone could help me out on this one, for some reason in the last couple months i have only been receiving the dispatch side of comms on NOR OPP freqs in Thunder Bay. Never had this problem before just the past two-three months it has been doing it and i havent gotten around to fixing/troubleshoooting. Was wondering if anyone could help me out on this one
als_medic
Same
I recently moved to Thunder Bay and have been having the same problem. I thought maybe I was listening to the repeater input instead of output, but don't know if that's the problem. I'm an avid listener, but not great at frequency searches or problem solving. Any thoughts?????
IdleMonitor
The Ottawa Valley - Eastern Ontario
Do you have the input frequencies programmed? http://www.radioreference.com/modules.php?name=RR&aid=577
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
When the old NOR system was active down in the Windsor/Essex County area, hearing only one side of the conversation was very common. Apparently, the patrol car has the ability to select the ability to repeat itself or stay private. Likewise, the dispatcher can also place the conversation into "repeat" mode automatically. That being said, in order to hear the patrol car(s), you would need to monitor the input frequencies, and have a good outdoor antenna, so you can hear signals in the distance.
73's
Ron
mikewazowski
Staff member
Forums Manager
Oot and Aboot
As Thunderbolt said, one sided conversations was the norm.
The only time you would hear the car was during a tower call or when the dispatcher kept the mic open while the car talked.
Cars did not have this option.
