BatmanofGotham1234
- Joined
- Nov 18, 2023
- Messages
- 1
Just bought a handheld Uniden Bearcat Radio Scanner BC89XLT 50 Channel 800MHz, trying to find out what frequency I can listen to Norwich fire& pd??
I had one of those back in the day, I loved that scanner it was a hot receiverJust bought a handheld Uniden Bearcat Radio Scanner BC89XLT 50 Channel 800MHz, trying to find out what frequency I can listen to Norwich fire& pd??
Welcome to the RR forums. Building upon what was already mentioned you will need a P25 Phase-II capable scanner to listen to Norwich police & fire on CLMRN. Talkgroups are TDMA (mode "T") so a P25 Phase-I scanner won't work in this case. Detectives are fully encrypted (mode "TE") so you won't be able to pick them up. Strongly recommended to use a Uniden SDS100 or SDS200 to overcome simulcast distortion you'll likely face monitoring with anything else
I hear Norwich PD and Norwich Fire with no issues on an SDS100, with a stock Uniden antenna, as well as my SDS200. No issues at all.I have purchased a Uniden SDS200 based on what a friend told me who lives in my same general area and currently has problems picking up the Norwich Police on their new system.
I have had problems listening to the Norwich Police on my Uniden BCD996P2.
I guess as you say "Whiskey3JMC", my problem is simulcast distortion.
However the Norwich City and Volunteer Fire Departments come in great with it (BCD996P2).
When the Fire Departments DO change over, I will need to put that SDS200 in service.
I sure do miss the days of the high, low, and Ultrahigh band programmable scanners.
Just put in the frequency, hit enter and it worked great.
Driving from Connecticut to Fla., years ago I heard every major fire and police dept that I passed through on I-95 using a portable programmable scanner.
I just added or deleted the frequencies as I made a stop about every 2 hours.
Does anyone know the frequencies for the new 800 system for the Norwich fire dept?
I have Norwich Police in my 996p2 and their
Coming in great. I tried the same frequencies with the fire dept and don’t even have a signal. I have an antenna on the roof and using lmr400 cable. I forgot the name of the antenna, But it’s like a X
857.0125 | M | 103.5 PL | Norwich F/G 1 | Fire Ground 1 | FMN | Fire-Tac |
857.0875 | M | 203.5 PL | Norwich F/G 2 | Fire Ground 2 | FMN | Fire-Tac |
857.8375 | M | 103.5 PL | Norwich F/G 3 | Fire Ground 3 | FMN | Fire-Tac |
Portables yes, mobile radios ... no. Most retain their prior mobiles, in addition to CLMRN.That Norwich Firefighter also told me that all of the older high band radios have been taken out of the trucks as well.
Each member working is also carrying around the new portable radios.
The Volunteers joined CLMRN at the same time at The City department. Each volunteer department now has Unication G4 pagers. While some still use their Minitor or Unication G1 pagers (depending on fire company) , the G4 pagers have been in stations for months now. I have had a hand in assisting with the adjusting of some G4 pagers to be more effective in use, so I have first hand knowledge of this.In regards to the above, I very recently talked with a Norwich Firefighter and he told me that they (the Norwich FD) and I assume the Volunteer fire departments, are now operating on the new 800 mhz channels.
