one more time?
Right now I have all the talk-groups in one TSYS. I like programming it by my self because I can learn more about scanning. I listen to sioux falls tower 44. I live near I-229, about 10 blocks from fire station 5 or so.
I'm not sure how you set it up to do that. Like the file you sent me it had things I never listen to in it, so I created my own with stuff I listen to. I don't want like city taxi things or anything. Just what I program it to do. I talk to another person he had the same problem kinda and gave them there own TSYS and it worked. But I forgot to ask him about this.[Unlimited;1357851 QUOTE]= It is still scanning talk groups when you only have about 5 freq. in the system freq. And the T in the top left corner that appears. I mean, will it still scan and broadcast audio when it comes across?[/QUOTE]
You only need one freq per tower Which is the Control channel 157.8600 is the current. Sioux Falls has several towers but they all are set up the same way.
Sioux Falls fire dispatches on 6 (text, station alarm, MDT, and Digital paging)
then they switch to 1 to 5, Morning radio test is at 8*30am.
Did you set up the band plan for your scanner? Look in the data base for that. That could be the thing holding you up
South Dakota State Radio System Trunking System, Statewide, South Dakota - Scanner Frequencies
Hope everything works out. If not send me a private message and I can just clone my scanner to yours.
