zidatc
Finally set up with a couple favorite lists. Went to one for a while, tried to go back to another list and it says there is nothing to scan. Help! Uniden BCD436HP
Start here for a list of things that would give you the 'nothing to scan' message.Finally set up with a couple favorite lists. Went to one for a while, tried to go back to another list and it says there is nothing to scan. Help! Uniden BCD436HP
GPS has no effect on Service Types, only on which systems are enabled (or avoided) based on your actual location. Doesn't matter whether you are using the full database, with location by a GPS in use, or a Favorites list with a GPS and location in play. If your service types are set correctly for what you want to monitor, the scanner will only try to monitor the types that you specified, that are also within the range settings you chose. Remember that range, when it comes to which systems are active, is a combination of the range of the system, as well as the range setting in the scanner itself. A more complete explanation is here: How it Works: Location, Location, LocationI’m going to look into those. If I want the same service types everywhere I travel, do I even need favorites lists with a gps?
