Jvandegrift194
- Joined
- May 30, 2021
- Messages
- 5
- Reaction score
- 0
Hi all, looking to see if anyone know what talk group NWS Earle uses for fire dispatch. I only see tactical talk groups on their system. Thanks all
I was looking in here: USA/NJ/Monmouth. I can see NWS Earle in the drop down but it’s blank, only the Gateway Natl Park/Sandy Hook items show.Is anyone able to load NWS Earle into SDRTrunk using the RR download? It only comes up blank for me.
I can see them now - thanks very much! - BillCI was looking in here: USA/NJ/Monmouth. I can see NWS Earle in the drop down but it’s blank, only the Gateway Natl Park/Sandy Hook items show.
Yes there’s been lots of Midlantic activity. The roll calls are also frequent. Haven’t heard much “local Earle” though.On ID search- This morning heard what sounded like fire dispatch do a roll call of all stations and any apparatus that was out of service on TG 27506 (which isn't listed in the DB under Earle)
Edit: Just found 27506 listed under other bases as: MidLant Fire Dispatch
For those who might be looking in the future. You can find NWS Earle under the DOD section which is oddly located under “county trunk systems”Yes there’s been lots of Midlantic activity. The roll calls are also frequent. Haven’t heard much “local Earle” though.
From what I have observed they will change to the Monmouth County channels to call in and communicate with themI've found the Local NSWE groups and the Midlantic ones active. The rest are all out of the area.
Any idea if the Leonardo and Colts Neck are "simulcast" - i.e. the same information all the time, so that one only needs to tune into the one closest/best signal, or is there good reason to listen to both? I am trying to do this by ear but it's tricky![]()
You're gonna want to program both, I've yet to see any simulcast! I'm down in the Norfolk/Virginia Beach area (I did live in Monmouth County for five years and I know NWS Earle quite well) and I have seven sites programmed in to cover the area. I know, sounds crazy and especially around here is practically Navytown, USA. But, the base fire departments here are quite active, and respond off base with automatic aid agreements with all of the cities around here. Just tossing in my $0.02 in for pontification (if you willl) lol.I've found the Local NSWE groups and the Midlantic ones active. The rest are all out of the area.
Thanks, I logged them you’re correct, and ColtsNeck and Leonardo can be different but sometimes the same. SDRTrunk seems to handle it well. The MidLant tg covers a lot of geographies but has some good traffic.You're gonna want to program both, I've yet to see any simulcast! I'm down in the Norfolk/Virginia Beach area (I did live in Monmouth County for five years and I know NWS Earle quite well) and I have seven sites programmed in to cover the area. I know, sounds crazy and especially around here is practically Navytown, USA. But, the base fire departments here are quite active, and respond off base with automatic aid agreements with all of the cities around here. Just tossing in my $0.02 in for pontification (if you willl) lol.
