NX-1000 Series
joehoose2700
Milwaukee, WI
Hello. Does anyone have a comparison sheet of all the NX-1000 series radios that are shown on the Kenwood USA website? There seem to be many versions - For example, the 1300 has an AU, DU, and NU. I also see a 1302. What's the difference between them all?
Also, I've seen a few threads describe this as "low tier" - what do you all mean by that? What might be a good use for a "low tier" radio, and what would you consider a higher tier?
For background, my radio use comes mostly at an outdoor education camp - some rough handling by camp staff (dropping, ending up in the dirt, etc.) but nothing super tough like firefighting or something like that lol. We currently have NX-320's (which tier are these?) and I personally have several 3300's that I use to supplement at large events.
Thank you!
kd4efm
EL98 Florida
The nx3000 and nx-x20 series is middle class, difference is, the 3000 would do nxdn or dmr, plus analog. And 1000 channel capacity
The 1000 series will do 1 digital and analog. Can be upgraded to the other digital as an option (fee), and analog can be upgraded to support a digital mode. A_K model.
Not as many channels though.
Evans works at a Kenwood dealer, listen to him, he knows what he is talking about.
AU = analog only
DU = analog and DMR
NU = analog and NXDN
As he said, you can upgrade the radio to add/change digital modes.
Low tier as in designed for business/industrial type users. It's not intended for "public safety" use. While I'm sure it's a durable radio, it probably wouldn't be the best choice for installation in a public safety vehicle where it was seeing constant use 10-12 hours a day every day.
For ham radio/hobby use, it'll be perfect. For business use, industrial use, it'll be just fine.
Mid tier is the NX-3000, would work for public safety use, but all the options aren't there. I use NX-3000 portables at work. I've been carrying an NX-3400 every day for a few years now and it's a solid radio. More features than the NX-1000, like NexEdge trunking, more channel capacity, FPP, some other trunking features.
High tier would be the NX-5000 line. A lot more features that make it friendly for public safety use, P25 trunking, man down, feature set that would apply well in public safety use.
Thank you!
NX-1000 would be fine.
I've got a bunch of NX-420's in use at a large event center and they've done just fine. I'd have no problems giving them NX-1000 if they supported my trunking system.
Remember, someone that is hard on radios is going to be hard on it no matter what you give them. Someone determined/negligent enough will destroy a radio no matter what you give them. Sometimes you have to look at replacement costs based on that. In other words, don't give a fool a top tier radio.
Project25_MASTR
Millennial Graying OBT Guy
Texas
To add, one of the major missing features between the NX-1000 series and NX-3000 series is that the NX-1000 series does not have Bluetooth which translates to them not being functional with Trackuracy Tier 1 and Tier 2 systems.
joehoose2700
Milwaukee, WI
So a 3000 would have both DMR and NXDN built in automatically, while a 1000 would be an either/or unless you upgrade?
Correct.
However, the NX-3000 radios will only handle one digital mode at a time. You can have Analog and NXDN -OR- have Analog and DMR. You cannot run NXDN and DMR at the same time on the same codeplug.
If you want to run Analog -AND- DMR -AND- NXDN, then you need the NX-5000.
natedawg1604
Colorado
I have multiple 3720's (mobiles) in VHF that work absolutely awesome, I use them for my local VFD, SAR and scanning a bunch of local VHF stuff. I've had zero issues with them.
