NX 200/700 programming
coling223
Maine
I have a NX 200 and 700, I have the 700 all programmed the way I want it and I just got a NX200. I have tried copy/pasting the codeplug data from one to the other with little (read) no success. Any pointers? I don't think my fingers can take doing another 6 zones and 30+ Ch. in each.
Thanks in advance,
Colin
Josh
Auburn Hills, Michigan
Load the data from the first radio, then click the "model" drop box at the top of the programmer. A window appears with various radios. Change it from NX700 to NX200 and it should change models.
You'll have to set radio-specific things to your liking, but aside from that the frequency data should be good to go.
coling223
Maine
Thanks for the reply, seems to have mostly worked, except I can only access 16 channels from the rotary knob. I know it is only designed for 16 thus the little plastic bar on the base of the knob that I removed right off the bat. When I had my initial codeplug in there, i had 20 something channels in there and had no problem going through all of them. Now it gets to the 16th channel and starts at the beginning, even though it scans the channels past 16.
Thanks again,
Colin
evfd1625
Indiana
Wirelessly posted (Opera/9.80 (Android 4.0.4; Linux; Opera Mobi/ADR-1301080958) Presto/2.11.355 Version/12.10)
You can set the knob to be continuous or end stop under the radio options.
evfd1625
Indiana
You have to use a spanner that can grasp both sides of the nut in the slots, remove the nut, then the plastic stopper, and replace the nut.
ces911
Thank you.... All done :) Sweet
