NX-200 Backlight Question
NWFD22
Walton, IN
So i am looking for a way to enable the backlight to come on any time the radio receives a transmission....Or am i stuck in fantasy land? Thanks for any help!
kd4efm
Florida
Have to turn off any hot key or button for back light, then options feature 1, auto back light will turn on.
kd4efm Evans, sent using TapTALK on my HTC M9
kd4efm
Florida
Auto Back Light function for NX-x00 portables
(minor correction to my last statement)
Edit > Optional Features > Optional Features 1 > Common Page 1
Auto Backlight
Auto Backlight allows you to enable or disable the Auto Backlight of the transceiver LCD to be lit automatically by pressing any key other than the PTT switch and the Volume control.
Range:
Check (On):
Enables the Auto Backlight.
Uncheck (Off):
Disables the Auto Backlight.
Default:
Unchecked (Off)
Note: Auto Backlight is disabled if "Backlight" is assigned as Key Function to any key.
Available Models with this Function
Model Name Availability of this Function
NX-200/ NX-210/ NX-300 NX-410/ NX-411 YES
NX-200G/ NX-210G/ NX-300G YES
NX-203/ NX-303 YES
NWFD22
Walton, IN
I have found that but, that is only when you push a button. I want it to come on automatically when it receives a transmission. No such luck yet.
kd4efm
Florida
No, only the NX-5000 does that. As I posted the Help File response for AutoBack Light, pressing any key.
And that's from the just release 4.95 KPG-111DNK.
