NX-300 Code Plug ?
Firebuff880
Boynton Beach, FL
So the community announced they are used FRS Channel 6 for Hurricane ops ..
While I don't have any FRS gear, I do own some older NX-300 UHF radios. Does anyone have a code plug I can load or do I need to build one from scratch -- Have all the software just looking for a code plug -
TIA --
MSS-Dave
Generally Central Florida
So just add FRS Channel 6 to either an existing Zone you have or create a new Zone with one channel. It's 462.5625. What you need now is the squelch code that they're using or select CSQ and hear everything including noise.....
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Firebuff880
Boynton Beach, FL
Dave, Thanks that what I was doing when you replied -- CSQ = QT/DOT none ??
Been a couple of years since I did anything with the Kenwod KPG code --
TIA --
MSS-Dave
TIA --
Correct. If you are wanting to talk to them though, need to make sure you match your TX code to their RX code unless they are doing carrier squelch too.
