NX-5300 P25 Not working
rescue161
KE4FHH
Hubert, NC
12.5 and 25 has nothing on P25! It's only about analog!
Here is where you set P25 moduilation in Quantar. Here WIDE PULSE means 3.0 kHz ±5% and NARROW PULSE 2.83 kHz ±5% of P25 CAI deviation.
In case of Kenwood, you must use NARROW. WIDE will not work. Because Kenwood don't have demodulator compatible with 3.0 kHz digital deviation.
DO NOT MIX IT UP WITH WIDEBAND/NARROWBAND AS MANY USERS ABOVE.
They go hand-in-hand. Per the Quantar manual, you can only use a Wide Pulse setting on a 25 kHz channel.
RK3AAG
Russia
You can use virtually any combination. But for proper P25 WIDE operation you must select:
CHANNEL INFO - CAI RX WIDE DEV
RF CONF - WIDE PULSE
And if you're using mix mode (ANALOG / ASTRO CAI), you also must set RECEIVCE CH BW to WIDE 25-30 kHz.
But I think that P25 WIDE is oblolette digital modulation and requires wideband permission from FCC, because it's not narrow-band compatible. I think so.
BEWARE: These settings are NOT compatible with Kenwood!
Ok so my RF Config is wide pulse for sure.
If I move it to narrow pulse, perhaps based on what you guys are saying the kenwood radio will work.
However, please educate me on what this narrow vs wide pulse actually is and what it means.
Does narrow pulse decrease my effective footprint?
Is wide pulse better overall in terms of maximizing my P25 footprint. Furthermore will APX and XTS/XTL and bendix king subscribers still be able to use the p25 side of my repeater on narrow pulse.
I don't want to move my quantar to narrow pulse if it degrades performance of my system. I'd rather just not use the kenwood radio if that is the case.
Sorry for all the insistence on 25 kHz vs 12.5 KHz. I just don't like narrow band since in the ham world wide band is still allowed and is better in terms of range. I hope ham bands will never go narrow band.
ke6yjc
Fresno, CA
Okay, I need to get one on one with you, but here is what I have and is my bench test. (photos)
The only thing I need to ask for is the same information back to confirm what I think is going on. We can discuss this in private email to each other, but I have a notion as to what is going on.
Back to you.
All looks good, except for this piece, the repeaters that the Kenwood is working with are configured with WIDE PULSE as shown below/attached. The only difference is that even though this is set to WIDE PULSE the repeater owner (which the Kenwood NX-5300 is currently working through) set the MODULATION COMPENSATION via the alignment tools to 3.5 kHz per the the help Quantar Help files.
FYI: I'm just passing this information along 3rd party if you want to talk all Quantar GEEK mode then let me know and I can pass the repeater owners information onto you privately via a PM.
Hope this helps us all!
Ted/KE6YJC
RK3AAG
Russia
Narrow pulse is not worse than Wide. You have nothing to lose
Change all your fleet settings and you will go with Kenwood. There is a digital modulator control in Quantar, XTS, XTL and APX. Not sure about BK.
ke6yjc
Fresno, CA
Well it's confirmed switching the "ASTRO TX filter" to NARROW Pulse fixed the issue. Can hear P25 on the NX-5300 now! YAY!!!!
