NX-5700 and NX-5800 audio
chief1110
Greenville (Greene County) NY
I just put in a dual deck dual head, with the deluxe control heads, when the radios scan how do I get audio out of both at the same time, I have the external speakers hooked to the deluxe heads.
KK6ZTE
California
If you have the speakers attached to the heads you'll only get selected audio out of the heads.
Each deck will need a speaker to do it right. Truck I'm building right now has a VHF for fire primary and VHF/UHF for secondary/medics. The primary is using audio off of the control head but I need to speakers via KAP-2 kits off of each deck for simultaneous receive.
There's a single audio output option that allows you to use one speaker but I highly recommend against it as it's on a priority basis.
KK6ZTE
California
Not directly, but you can set a -3dB or -9dB unselect audio offset, which you can adjust via menu if you set it as a menu item.
Also, you can program a button or menu option for Unselected RF Deck Speaker which will mute/unmute the unselected decks
DarcyB
In my setup, I use the -9db audio offset for the unselected decks, feed all of the spkr out's through a level converter, summing mixer and audio power amp to feed the speaker. The summing mixer was modified to have mechanical stops to ensure that audio is never fully muted in the mixer, and was installed in the console in such a way to allow adjustments if necessary, but is protected enough to ensure that those adjustments are not made accidentally.
wd9cms
New Mexico
DarcyB,
I like your audio mixing setup! Do you have any installation pictures on how you mounted the mixer?
Thanks,
Bill
KK6ZTE
California
Are you using two separate LOCs or a 4 channel LOC like this:
DarcyB
DarcyB,
Thanks,
Bill
I'll try and remember to get some pics next time I'm near that rig.
