NX-5700 export to NX-5200 how?
ve2mel
Saint-Pascal, Québec, Canada
Hello, could someone help me tell me what procedure I should use to read an nx-5700 radio and write it to an nx-5200. when I try I receive an error message that says that I am not the right model and the market code. I don't know if I can export and import an .itm file? I also don't understand why I'm stuck there... I've never had a problem before to program radios. thank you for helping me.
Eric, VE2MEL
kd4efm
EL98 Florida
Eric, go to product information, change to a 5200, make your key assignment to your portable, program it.
Done.
  • Like
Reactions: RRR
kd4efm
EL98 Florida
It's okay, I have my moments too, Also, the IMPORT part you can from 111 or 141 to the NX 5000. But not from D1 export. That only produces a html output.
But yes, that error message can also come up when you have un-activated features between one and another too!
So make sure you also have matching activated items or it wont populate and program to what you are cloning.
wd8chl
Now, going from a NX5200 to a TK5230 is a no-can-do, at least not by that method. It will tell you "All data will be erased." Ugh...
kd4efm
EL98 Florida
That's because it's a whole different codeplug structure and minus the dmr and nxdn subsets.
EWC_BDN
To go from 111d you need to set the D1 product info to NXDN too. I had a 500 channel CP I had to move over and that's what I had to do. It was all analog, but still required that.,
