NX-5K Series Lock and Unlock
AF1UD
In the process of programming some subscriber units, I would like my users to be able to lock the keypad and channel selector and then unlock all from the portable. I see there's a check off table relating to key lock on the key assignment tab.
Does the key lock programmable button do both locking and unlocking?
Thanks!
tweiss3
Is it time for Coffee?
Ohio
Yes. I have the orange emergency button long press as lock/unlock.
AF1UD
Wow... if only EFJ could follow suit with Armada options.
jcefd10
WWG1WGA
I use the A/B selector on the 5200's for lock, and one of the side buttons below the PTT on the NX1200' s and 220's we use.
I tried the front buttons on a couple a found out it would lock when the users didn't want by hitting something, so I moved it.
AF1UD
What are you having problems with? Viking keypad lock behavior works as advertised in my experience.
After locking it, I couldn't unlock it without setting a "Soft Menu" button to Unlock.
DeoVindice
P25 Underground
Gadsden Purchase
What radio and firmware? I have the two-position toggle switch used for keypad lock on VP6000s running 8.40.20.77. The radios unlock when the toggle switch is moved back. I've also used press-and-hold of the emergency button for lock/unlock on VP6000s and 5000s (same hardware as the NX5000 portable).
AF1UD
VP8000 latest firmware.
n7maq-1
Oregon
Understood. I'd suggest reporting it to technical support, the 8000 firmware stack is quite a bit different from the 5000/6000 and has its own bugs.
My two-position toggle switch works fine as a lockout on my VP8000. Firmware is 8.42.12.103
By the way the Armada (1.42.15) that hit the market today still has a bug with 151.4 CTCSS.
Jim
AF1UD
Jim
Dumb question, but what bug is that?
