NX-700H AUDIO LINE OUT
kd4efm
Florida
Yes, there's flat audio out, and discriminator audio(for data)
Sent from my SM-G965U using Tapatalk
kd4efm
Florida
You can use pin 17 and 18, or the external speaker Jack if you just using it to record stuff.
KK6ZTE
California
AFO (pin 17) referenced to ground (pin 18) is your best bet. Fixed level audio output (unaffected by volume control).
magic_lantern
Thanks guys, that is what I needed. The radio is the dispatchers and the external speaker would be adjusted by various people and would require constant level adjustments of the sound card.
