NX1200 scanning issues
Hi there hoping you all are fine, recently i bought from a local dealer a Kenwood NX1200-NK2 (LCD version), i programmed it as usual but in the field i noticed that when the radio is scanning sometimes there is no sound coming out of it, i have another radio with the same frequencies and there´s no problem when scanning.
i tried yet putting a blank codeplug and then putting the frequencies but it has no result.
i forgot to mention that when radio is not scanning there is no problem hearing comms and transmitting, it only has issues when the function is on
73´s
wd8chl
73´s
Check to make sure that all the channels you want to listen to have "Scan Add" checked under "Channel Edit"-"General" for each channel. Then make sure everything is set the way you want in "Scan Information"
