I've posted this on any of the other Kenwood NX radio firmware threads, but putting it here so others will be aware before upgrading:
Finally had a chance to sit down and go through all the information on the new firmware.
This is important:
If you update to the latest firmware (3.2) you MUST use the KPG-111DN software to program. The big issue there is that the KPG-111DN only lets you do 12.5KHz narrow bandwidth channels. You cannot program any 25KHz wide bandwidth channels after you upgrade. There is a way to get a key to unlock wide band, but you have to go through Kenwood, and it doesn't look like they make it really easy to do.
So, before you upgrade, you need to decide...
If you are an amateur radio operator, you probably wouldn't want to do this.
If you use them on GMRS, you'd need to decide if you want to put up with narrow band. It's just fine for some, but others, specifically those that use a lot of repeaters, may not want it.
