NX5200 & NX5700 ADP
firemedic834
Is ADP encryption standard with NX5200 and NX5700 or is an encryption module required?
ADP is available in in the DMR side only, as far as I know. Kenwood refers to it as "ARC4" which is the standard name for it.
It's a software add on, no crypto module required.
dryfb
America
P25 too afaik, license upgrade for p25 arc4 is free, dmr enhanced encryption is not iirc
You are correct, it's an option on the P25 side as well as DMR. I think originally it wasn't included. They added it when the other company started giving it away.
otobmark
NC
My NX5300 has arc4 license and it only works for P25, NOT DMR. Haven’t tried NXDN.
You have to add the DMR ARC4 feature license. KWD-5500EE
I don't believe the NXDN side supports ARC4. It only does the 15 bit "scrambler", or you need to add the DES/AES option.
FD101
GØT AES-512? It's the next best thing!
YMH
Correct.
The DMR ARC4 also costs $43.20 while the P25 ARC4 key is free.
tweiss3
Is it time for Coffee?
Ohio
Every NX5K I have bought also had DES 4 key included.
buddrousa
I just checked and tested My 5200 with DMR Key Added ENCRYPTION IS GRAYED OUT as we did not by the ARC4 KEY.
Below is a copy from the Kenwood Dealer Site For the NX-5200/NX-5300 Radios
■GENERAL FEATURES • 6 W (136-174 MHz) Models • 5 W (380-470, 450-520 MHz) Models • 1024 CH-GID / 128 Zones • Standard Key Models (w/o numeric keypad) • Full Key Models (w/ numeric keypad) • Full Color 1.74" (240 x 180 pixels) Transflective TFT Display • Multi-line Text Display • Function/Status Icons • Multi-Language Display • Date & 12/24 Hour Time Clock • Transmit/Busy/Call Alert/Warn LED • On/Off Volume Knob • 16-Position Mechanical Selector (w/ a stopper) • 4-way Directional-pad (D-pad) • 2 Position Lever Switch • Emergency/AUX Key • 3 Side PF Keys • 1W Speaker Audio • Multi Digital Protocol 1 • Emergency Call Features • Built-in GPS Receiver / Antenna • Built-in Bluetooth®4.0 Module • Built-in Motion Sensor • Built-in 56-bit DES Encryption (4 keys programmable by KPG-D1(N)K) • Active Noise Reduction (ANR) • KPG-D1N Windows®FPU • Flash Firmware Upgrading • MIL-STD-810 C/D/E/F/G • IP67/68 Immersion • Color Housing Option • Digital Encode/Decode Format
■DIGITAL –NXDN® MODE • NXDN®Conventional / TYPE-C (Gen1/Gen2) Trunking • AMBE+2 VOCODER • 6.25 & 12.5 kHz Channels • Over-the-Air Alias • Over-the-Air Programming • Paging Call • Emergency Call • All Group Call • Digital Two-Tone • Status Messaging • Remote Stun/Kill/Check • Short & Long Data Messages • GPS Location • NXDN®Scrambler
■DIGITAL –P25MODE • P25 Conventional Option • P25 Phase 1 Trunking Option • P25 Phase 2 Trunking Option • Conv/Trunking OTAR Option • Conventional Voting Scan Option • Packet Data Option for P25 OTAR & GPS • Text Data • Radio Authentication • Tone Paging • ARC4 Encryption Option
■DIGITAL –DMR MODE • DMR Tier 2 Conventional Option • DMR Tier 3 Trunking Option • DMR Auto Slot Select (DASS) • AMBE+2 VOCODER • 12.5 kHz Channels • Over-the-Air Alias • Over-the-Air Programming • Call Interrupt (Direct & Repeater Mode) • Paging Call • Emergency Call • All Group Call • Late Entry • Status Messaging • Remote Control by Subscriber Units • ARC4 Encryption Optional • Site Roaming
otobmark
NC
If the encryption module is installed do you get AES256 on everything? I will keep using the NX series I have but don’t want to put too much into them (module) since I’m moving to Viking going forward. We have cashes of NX1300 DMR radios and I really don’t know what the encryption options are there.
buddrousa
This post is off of the Dealer Website NX-5200/NX-5300/NX-5700/NX-5800 Radios.
GENERAL FEATURES
4000 Channel (KWD-5000CH) •
Front Panel Programming (KWD-5001FP) •
microSD/microSDHC Memory Card Slot (KWD-5002SD) •
Built-in Bluetooth® Module for Data (KWD-5003BT) •
Remote Control Commands by Subscriber Units (KWD-5007RC) •
256-bit AES Encryption (KWD-AE30K/31KEncryption Module required) •
Battery Management Solution (KSC-Y32KCharger & KAS-12KSoftware License Key required)
DIGITAL –P25 MODE
Conventional Features (KWD-5100CV) •
Phase 1 Trunking Features (KWD-5100CV& 5101TR) •
Phase 2 Trunking Features (KWD-5100CV& 5101TR& 5102TR) •
Conventional OTAR (KWD-5103RK) •
Trunking OTAR (KWD-5103RK& 5106DT) •
Conventional Voting Scan (KWD-5105VT) •
Packet Data required for Trunked OTAR/GPS (KWD-5106DT) •
P25 ARC4 Encryption (KWD-5107EE) •
Link Layer Authenication (KWD-5100CV& KWD-5101TR& KWD-AE3x Encryption Board Required)
KWD-5107EE License Key for P25 ARC4 Enhanced Encryption NC FREE
DIGITAL –DMR MODE •
DMR Tier 2 Conventional Features (KWD-5300CV) •
DMR Tier 3 Trunking Features (KWD-5300CV& KWD-5301TR)
KWD-5500EE License Key for DMR ARC4 Enhanced Encryption $43.20
I believe it does on P25 and NXDN. Never used the DMR function on these. Maybe someone else has and can confirm.
I have a bunch of the NX-1300's at work for various users, both DMR and NXDN versions.
They include:
NXDN 15 bit "scrambler"
Analog voice inversion scrambler
DMR ARC4 encryption is OPTIONAL, I seem to recall there was some built in "scrambler" or low level encryption option on the DMR side, but I don't have my programming laptop here at home to check/refresh my memory.
racingfan360
They include:
That's correct, for DMR the Kenwood also includes a 15-Bit Scrambler that's very similar to that used in NXDN mode
