Nx5200 programming question
nick223
Ottawa Illinois
#1
Just took delivery of 31 nx5200 portables. Software and cable provided. But the cable doesn't have the standard USB or a serial plug.
The cable is a kpg 93. Do I need some sort of adaptor.
Do they make a USB programming cable ?
Point Nemo.
#5
That IS the KVL cable.
KVL = Key Variable Loader. It's for loading the encryption keys for the AES/DES optional module. The other end of the cable interfaces to the KVL-3000 or KVL-4000.
The programming cable you need is the KPG-36XM for the "full speed" loading. The KPG-36U works just fine. It's cheaper and slightly slower. Dealer probably just sent you the wrong cable, give them a call and they should exchange it for you.
