INDY72
I think you mean ID SEARCH until you know the IDs and can save them and name them. ID SCAN is for once you have a set of KNOWN IDs to scan.
And if you DO NOT CARE WHAT TG is being used by WHO, then set as CONVENTIONAL with the tone set to DIGITAL, and SEARCH unless you KNOW the RAN. If you want to know who is using what, you set a conventional as NXDN OFT, ID SEARCH ON. Then once you ID the TGs, put it to ID SCAN.
Same as you would do an DMR, or P25 frequency.
