NXDN Conventional Group Id's
#1
Hey everyone,
I have a quick question, or hope it's an easy one. We have a mix of about 60 or so nx 300's and 800's on a conventional digital voter system with several sites that are linked.
We have 2 main channels and we have 3 groups: Admin, team leaders, and route workers, but we do not use any of the calling features.
We have only 2 zones programmed, one for each channel. We primary work off the main channel. We do use UIDs and over the air alias which works ok, but I'd like to be able to display what group id is talking since we have a good amount of people that are moving within the company.
We want all radios to hear the transmissions but have different group IDs, we just want to be able to see the group ID on the display for each group, is this possible?
I see that each zone only has one place to select a group id, so I wasn't sure.
Thanks in advance
Florida
#2
Yes, there is, it's in the NXDN tab, under unit ID name. Change to Calling ID/Group ID. It will show in the display then.
kd4efm Evans, sent using TapTALK on my HTC M9
Florida
#3
Also on channel edit, lower right, check box GID SCAN. If you want to hear the other groups. I do it with our ham radio NXDN network.
#4
Thanks, I have set to display by changing the caller id/group id it only displays admin which is group one. I will test out the gid scan. I'll report back
Thanks!
Sent from my LGLS991 using Tapatalk
