NXDN ENC
Lorain Cnty, OH
#1
More ENC NXDN sites popping up
424.0625 KQB214 E.CLE PD
424.9625 NXDN96 RAN:27 (ENC)
7000 (BASE)
7009 (CBS 909)
7612 (CBS 912)
7620 (CBS 920)
7621 (CBS 921)
7624 (CBS 924)
7626 (CBS 1126)
464.6875 NDXN96 "ENC"
464.9375 NXDN96 RAN:40 "ENC"
31000 (SECURITY BASE)
31002 (SP UNIT 2)
31018 (SP UNIT 18)
31019 (SP UNIT 19)
31026 (SP UNIT 26)
jdolina
Lorain Ohio
#5
424.9625 I believe is the ican charter schools I have seen TG with i can XX
424.975 RAN:27 same as above
I can add the following as NXDN enc I have found
463.775 RAN:40 Which I believe is Lutheran hospital security based on TG LU SEC LU BASE
WQOQ369 (CLEVELAND CLINIC) FCC Callsign Details
461.7375 RAN:44
463.2625 RAN:35
464.6875 RAN:30 TG's base and xBUS
16b
Central Ohio
#7
Kind of ironic you didn't realise that given your profile pic.
Sent from my SM-T350 using Tapatalk
I have programmed and used encryption on various two-way radios, and I can't recall ever seeing it referred to as "ENC." I believe scanners use this terminology? It is confusing/misleading because it is not an acronym, yet it is almost always written using ALL CAPS.
OHIOSCAN--thanks for the information. The reason I was confused was because you also listed additional information like "BASE" and "BUS 43" that one would normally not be able to determine without listening to the radio traffic. I know Nexedge radios have a text ID field that can be transmitted along with the regular numeric unit ID. Is that where you are getting this information?
Lorain Cnty, OH
#12
Random NXDN logged notes
420.0375 NXDN48
422.9625 NXDN48 SITE R202-36
424.0625 NXDN96 RAN:13 KQA214 (ENC)
RIDS: 10,27,30
424.9625 NXDN96 RAN:27 (ICAN CHARTER SCHOOL?)
7000 (BASE)
7009 (CBS 909)
7612 (CBS 912)
7620 (CBS 920)
7621 (CBS 921)
7624 (CBS 924)
7626 (CBS 1126)
452.7000 NXDN96 VOICE
453.1000 NXDN96 VOICE RAN:1
453.2750 NXDN96 VOICE RAN:13
453.2875 NXDN96 VOICE
453.5250 NXDN96 VOICE RAN:19
TG
RID 33 DISPATCH
RID 221 UNIT 527
RID 366 UNIT 762
RID 2221 UNIT 539
460.3875 NXDN96 SITE L231-1
461.4000 NXDN96 VOICE
461.6250 NXDN48 VOICE RAN:19
461.7375 NXDN RAN:44
463.2625 NXDN RAN:35
464.6875 NXDN RAN:30
463.9375 NXDN48 VOICE (UNID SCHOOL)
464.0750 NXDN96 SITE L290-1
464.2125 P25 (ENC)
TG# 1
RIDS
1804923
1804925
7604910
464.2750 NXDN96 VOICE
463.7750 NXDN RAN:40 LUTHERAN HOSPITAL SECURITY
464.5625 NXDN48 VOICE RAN:10
464.6875 NXDN96 RAN:30 (ENC)
5000 [BASE]
5007 [BUS 43]
31000 (SECURITY BASE) ENC
31002 (SP UNIT 2)
31018 (SP UNIT 18)
31019 (SP UNIT 19)
31026 (SP UNIT 26)
NEXTEDGE SITES
SITE 127-1 BASF ELYRIA
451.3625 NXDN96 SITE-L127-1 RAN:1 (CH-1 CC)
451.5375 NXDN96 SITE-L127-1
452.1375 NXDN96 CC SITE 127-1
452.4875 NXDN96 CC SITE L127-1
452.6875 NXDN96 VOICE / CC SITE L127.1 RAN:1 (CH-3 CC)
453.1000 NXDN96 VOICE SITE L127-1 RAN:19
453.2750 NXDN96 VOICE SITE:L127-1
453.5250 NXDN96 VOICE SITE:L127-1 RAN:19 (CH 3 CC)
TG#
2 RID 164, 169{THIERY}, 134{GAVALEK}
SITE L191-1 ELECTROCOMM UHF NE OH
PARMA
WPQC999
422.3375*VD
422.6125*V
424.5625*CC
424.7125
424.7625
424.9375
424.9625
424.5625 NXDN96 SITE L191-1 (CH 2(SCC) 4, 26, 182 CC, 216, 448, 1002)
422.3375 NXDN96 SITE L191-1 RAN:1
422.6125 NXDN96 SITE L191-1 RAN:1
SITE L191-1
SITE L191-2 CC=216
TG#
CH04 422.3375
CH26 422.6125
CH182
CH216
TG
7500 BASE ENC
7700 ENC
RID 7547
RID 7553 UNIT 53
RID 7710 PICKUP 10
RID 7811 TRUCK 11
RID 7822 F/LOAD 22
RID 7825 F/LOAD 25
RID 7826 F/LOAD 26
RID 7827 F/LOAD 27
RID 7828 F/LOAD 28
SITE 285-1
152.4125 NXDN96 SITE:L285-1 RAN:1
152.3250 NXDN96 SITE:L285-1 RAN:1
kbod9633
Charlotte Tn
#13
How hard is dsd to get setup? My local le went nxdn a while back and would like to seek out all the info for that site
nrf
Ohio
#15
this seems interesting, and inexpensive, but has anyone made the jump from hand tuning a channel to following a trunked system?
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
#18
424.9625 is licensed to ElectroComm. The "CBS" activity you guys have seen/see on there is likely an I CAN charter school somewhere, or the overseeing network.
L191 system (Electrocomm NXDN UHF) - https://www.radioreference.com/apps/db/?sid=9005
These are encrypted:
TG: 7000 ENC Appears to be I Can charter schools
TG: 7700 ENC looks like some place with a lot of front-end loaders
TG: 7800 ENC Appears to be a roll-off container company
All heard off of 191-1 Parma site.
Code:
NEXEDGE96, 191,       7000,     7000,     50,  Normal,      27,  2018/11/28 14:16,  *" BASE"
NEXEDGE96, 191,       7000,     7003,     50,  Normal,      29,  2018/11/28 14:06,  *"CBS 1176"
NEXEDGE96, 191,       7000,     7006,     50,  Normal,      15,  2018/11/28 14:02,  *"I CAN 6"
NEXEDGE96, 191,       7000,     7007,     50,  Normal,      12,  2018/11/28 14:15,  ""
NEXEDGE96, 191,       7000,     7008,     50,  Normal,      10,  2018/11/20 16:30,  *"I CAN 8"
NEXEDGE96, 191,       7000,     7009,     50,  Normal,      21,  2018/11/28 14:18,  *"I CAN 9"
NEXEDGE96, 191,       7000,     7010,     50,  Normal,      14,  2018/11/28 14:17,  ""
NEXEDGE96, 191,       7000,     7012,     50,  Normal,      28,  2018/11/28 14:13,  ""
NEXEDGE96, 191,       7000,     7017,     50,  Normal,       4,  2018/11/28 14:13,  *"I CAN 17"
NEXEDGE96, 191,       7000,     7018,     50,  Normal,       1,  2018/11/20 16:27,  *"I CAN 18"
NEXEDGE96, 191,       7000,     7600,     50,  Normal,       3,  2018/11/28 14:12,  ""
NEXEDGE96, 191,       7000,     7608,     50,  Normal,      59,  2018/11/28 14:18,  *"CBS 908"
NEXEDGE96, 191,       7000,     7611,     50,  Normal,      13,  2018/11/28 14:14,  ""
NEXEDGE96, 191,       7000,     7612,     50,  Normal,       2,  2018/11/20 16:30,  *"CBS 912"
NEXEDGE96, 191,       7000,     7616,     50,  Normal,      29,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7617,     50,  Normal,       2,  2018/11/27 20:57,  ""
NEXEDGE96, 191,       7000,     7619,     50,  Normal,       9,  2018/11/28 14:11,  *"CBS 919"
NEXEDGE96, 191,       7000,     7620,     50,  Normal,       8,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7621,     50,  Normal,      10,  2018/11/28 14:14,  ""
NEXEDGE96, 191,       7000,     7622,     50,  Normal,      16,  2018/11/28 14:16,  ""
NEXEDGE96, 191,       7000,     7623,     50,  Normal,      13,  2018/11/28 14:06,  ""
NEXEDGE96, 191,       7000,     7624,     50,  Normal,       3,  2018/11/19  7:08,  ""
NEXEDGE96, 191,       7000,     7629,     50,  Normal,      67,  2018/11/28 14:16,  *"CBS 1129"
NEXEDGE96, 191,       7000,     7630,     50,  Normal,       1,  2018/11/27 20:58,  ""
NEXEDGE96, 191,       7000,     7650,     50,  Normal,      32,  2018/11/28 14:14,  ""
NEXEDGE96, 191,       7000,     7651,     50,  Normal,      52,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7652,     50,  Normal,       7,  2018/11/28 14:15,  *"....F 60........"
NEXEDGE96, 191,       7000,     7654,     50,  Normal,       3,  2018/11/28 14:03,  ""
NEXEDGE96, 191,       7000,     7656,     50,  Normal,       3,  2018/11/19  7:00,  ""
NEXEDGE96, 191,       7000,     7658,     50,  Normal,       5,  2018/11/28 14:12,  ""
NEXEDGE96, 191,       7000,     7664,     50,  Normal,      24,  2018/11/28 14:18,  *"....528"
NEXEDGE96, 191,       7000,     7665,     50,  Normal,       1,  2018/11/28 14:05,  ""
NEXEDGE96, 191,       7000,     7666,     50,  Normal,      15,  2018/11/28 14:07,  ""
NEXEDGE96, 191,       7000,     7667,     50,  Normal,      59,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7668,     50,  Normal,      15,  2018/11/18 17:18,  ""
NEXEDGE96, 191,       7000,     7672,     50,  Normal,      26,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7000,     7673,     50,  Normal,      11,  2018/11/20 16:30,  *"CBS 1182"
NEXEDGE96, 191,       7000,     7674,     50,  Normal,       3,  2018/11/28 14:08,  ""
NEXEDGE96, 191,       7000,     7678,     50,  Normal,      19,  2018/11/28 14:15,  *"CBS 538"
NEXEDGE96, 191,       7700,     7723,     50,  Normal,      12,  2018/11/28 14:15,  *"F/LO....3"
NEXEDGE96, 191,       7700,     7724,     50,  Normal,       4,  2018/11/28 14:14,  *"F/LOAD 24"
NEXEDGE96, 191,       7700,     7725,     50,  Normal,       7,  2018/11/28 14:15,  ""
NEXEDGE96, 191,       7700,     7726,     50,  Normal,       2,  2018/11/28 14:13,  *"F/LOAD 26"
NEXEDGE96, 191,       7700,     7729,     50,  Normal,       7,  2018/11/28 14:15,  *"F/LOAD 29"
NEXEDGE96, 191,       7700,     7730,     50,  Normal,       3,  2018/11/19  5:11,  ""
NEXEDGE96, 191,       7700,     7731,     50,  Normal,      30,  2018/11/28 14:16,  *"F/LOAD 31"
NEXEDGE96, 191,       7700,     7732,     50,  Normal,       2,  2018/11/28 14:17,  ""
NEXEDGE96, 191,       7700,     7733,     50,  Normal,      19,  2018/11/28 14:18,  ""
NEXEDGE96, 191,       7703,     7703,     50,  Normal,      75,  2018/11/28 14:16,  *"BASE"
NEXEDGE96, 191,       7800,     7702,     50,  Normal,     144,  2018/11/28 14:18,  *"BASE"
NEXEDGE96, 191,       7800,     7741,     50,  Normal,      10,  2018/11/19  7:42,  *"R\OFF 41"
NEXEDGE96, 191,       7800,     7836,     50,  Normal,       6,  2018/11/28 14:11,  *"R\OFF 36"
NEXEDGE96, 191,       7800,     7837,     50,  Normal,      11,  2018/11/28 14:15,  *"R\OFF 37"
NEXEDGE96, 191,       7800,     7838,     50,  Normal,       5,  2018/11/19  7:56,  *"R\OFF 38"
NEXEDGE96, 191,       7800,     7842,     50,  Normal,       8,  2018/11/19  7:50,  *"R\OFF 42"
NEXEDGE96, 191,       7800,     7843,     50,  Normal,      14,  2018/11/19  7:27,  *"R\OFF 43"
NEXEDGE96, 191,       7800,     7844,     50,  Normal,      30,  2018/11/28 11:51,  *"R\OFF 44"
NEXEDGE96, 191,       7800,     7845,     50,  Normal,       4,  2018/11/19  7:33,  *"R\OFF 45"
NEXEDGE96, 191,       7800,     7846,     50,  Normal,       3,  2018/11/19  7:51,  *"R\OFF 46"
NEXEDGE96, 191,       7800,     7848,     50,  Normal,      28,  2018/11/28 14:18,  *"R\OFF 48"
NEXEDGE96, 191,       7800,     7849,     50,  Normal,       2,  2018/11/28 11:50,  *"R\OFF 49"
NEXEDGE96, 191,       7800,     7850,     50,  Normal,       3,  2018/11/19  7:58,  *"R\OFF 50"
NEXEDGE96, 191,       7800,     7851,     50,  Normal,      14,  2018/11/19  7:46,  *"R\OFF 51"
NEXEDGE96, 191,       7800,     7852,     50,  Normal,       2,  2018/11/19  7:15,  *"R\OFF 52"
NEXEDGE96, 191,       7800,     7853,     50,  Normal,      10,  2018/11/28 11:48,  *"R\OFF 53"
NEXEDGE96, 191,       7800,     7854,     50,  Normal,       9,  2018/11/28 14:13,  *"R\OFF 54"
NEXEDGE96, 191,       7800,     7855,     50,  Normal,      12,  2018/11/19  7:57,  *"R\OFF 55"
NEXEDGE96, 191,       7800,     7856,     50,  Normal,      20,  2018/11/28 11:50,  *"R\OFF 56"
NEXEDGE96, 191,       7800,     7857,     50,  Normal,       9,  2018/11/28 14:15,  ""
NEXEDGE96, 191,       7800,     7858,     50,  Normal,       4,  2018/11/28 11:47,  ""
NEXEDGE96, 191,       7800,     7859,     50,  Normal,      11,  2018/11/28 11:48,  *"R\OFF 59"
NEXEDGE96, 191,       7800,     7860,     50,  Normal,      11,  2018/11/28 14:08,  *"R\OF...."
NEXEDGE96, 191,       7800,     7861,     50,  Normal,      17,  2018/11/28 11:52,  *"R\OFF 61"
NEXEDGE96, 191,       7800,     7862,     50,  Normal,      17,  2018/11/28 14:18,  *"R\OFF 62"
mbstone99
Hamilton, Ontario
#19
> 420.0375 NXDN48
The 420.0375 could be the OnQ network (System 202) site in Chatham, Ontario (Site 14) while the 422.9625 is the Tilsonburg, Ontario site for the same network.
Matt
