racingfan360
- Joined
- Dec 19, 2005
- Messages
- 1,158
Thanks, guys.
Paul, thanks for taking this forward.
I've added two entries: note both are from my own system (and are the same fro those that I reported against here https://forums.radioreference.com/u...ms-n9600-conventional-nxdn-4.html#post2909170). That also means I can easily reproduce and re-run tests if that helps, and run additional UHF tests too.
At the risk of stating the obvious, I note the last firmware release made a significant positive impact on DMR simplex decoding: to be blunt, it took DMR simplex decoding from atrocious to good in one firmware step. But it would be a real shame if that deteriorated as a compromise as part of a minor improvement on NXDN decoding
