OK so let me help with some info here. I have spent a while doing my research and seeking out info on this system.
First off I keep seeing people say on RR "there is not band plan" for NXDN. That'a a bit untrue. Yes it is possible to setup all kinds of channel number plans but this system *so far* uses the standard UHF plan. Which I recommend reading this thread about:
https://forums.radioreference.com/voice-control-channel-decoding-software/298075-understanding-nexedge-trunking.html
In short NXDN broadcasts channel numbers OTA as we've all seen. Here is the *standard* plan:
Standard UHF Map Formulas
For Channels 1 to 400:
Freq = 450 + (( Ch - 1 ) * 0.0125
For Channels 401 to 800:
Freq = 460 + (( Ch - 401 ) * 0.0125
For Channels 801 to 1023
Custom frequency, i.e. T-Band or on a 6.25 KHz step.
What is the frequency for Ch 511?
Freq = 460 + (( 511 - 401 ) * 0.0125 ) = 461.3750
So with DSD+ and a SDR dongle it's actually very easy to figure out the details for a site on FleetTalk. (so far). If you have it then run it for a day or so, especially at busy times like weekdays, and then you should have a list of channels. Just plug that info into the formula above and in most cases you'll have all your frequencies.
The NC and SC FleetTalk systems are both 219, that we know, they are both linked. When you see a group where all the RIDs are "7" then that is coming across from one system to another. They are two systems of 30 sites each.
What would really be helpful to get this listed right is for anyone who can to use DSD+ and some time and monitor the control channels to get the frequency lists. Then use that formula to come up with the frequencies. Then AFTER that go ahead and run those frequencies through the FCC database to see if any license match up.
Another nice thing that anyone who has used a dual SDR setup with DSD+ will have seen is that NXDN sends radio aliases over the voice channels. So if you're tracking it with DSD+ you can see the names of the radios and that helps to nail down who may be talking or at least what company it might be.
Hopefully some or all of this helps and keeps the discussion going. I don't want to step on any toes or ruffle any feathers. Just want to get as much info out there as I can.
