NY/NJ PA LCN order....Please Help Me!
Staten Island, NY
#1
Good day all!
I need some expert advice.....please be so kind as to offer your help to me with the correct LNC order for the NY/NJ Port Authority EDACS Trunking system. Please click on the following Radio Reference link for clarification for my description of my dilemma.
http://www.radioreference.com/apps/db/?sid=408
The sys. freq.'s are listed as you can see at this link, but in a confusing LCN order. There are 4 different sites:
001 - Primary - freq.'s 01 thru 07
002- Holland Tunnel - freq.'s 01 and 02
003 - World Trade Center - freq.'s 01 thru 03
004 - JFK - freq.'s - 01 thru 03
There are duplicate 01, 02, 03, 04 LCN order numbers for the diff. frequencies listed. 4 freq.'s listed as 01, 4 as 02 and 3 as 03 with just 1 freq. listed for LCN 04, 05, 06 and 07.
If you look at the link you'll see what I mean. I hope!
Which correcet freq. order should be input into my scanner?
Should they be programmed in from left to right line by line (site by site), or in descending order, all 01's, 02's, 03's first then 04 thru 07?
I assume all sites mesh together, so just one bank of my scanner is used. I have the Pro-528 and will pick up a Pro-96 soon.
Thank you so much for your help!
Walter
Disabled USAF Vet.
walterjz2001@yahoo.com
#2
I wan't to know the same exact thing, do I have to use 4 different banks for each site or just one bank?
