NY SEMO "District 3"
SteveC0625
Northville, NY (Fulton County)
#2
Theres a state emergency management freq. listed as "district 3"
NYS Office of Emergency Management Scanner Frequencies and Radio Frequency Reference
I thought OEM was referred to as "regions"? Or is "district" something else?...
Old terminology. No one updated the database when everything was merged into DHSES. SEMO no longer exists under that name. It's now DHSES OEM. NYS Division of Homeland Security & Emergency Services - OEM
The database is built on user inputs. If no one updates, it quickly becomes less than accurate.
DaveNF2G
Rensselaer, NY
#5
SEMO's districts had names back in the day. I'm not sure when they went over to numbers, but DHSES definitely uses numbers now.
