gonzalu
Am I doing something wrong?
Anyway, I had my BCD996XT set to SCAN the Talkgroups in the NYC Transit Authority system I programmed straight from RR db. I decided to switch it over to SEARCH and see what I picked up. I am picking up a lot of TG IDs not in the db. Did I do something wrong and am actually picking up existing TGs that are unidentified?
So, here is how I have my scanner set up ...
System Setup:
Type: Mot Type II / P25
Use Motorola End Code - ON
Use Digital Motorola End Code - ON
Enable I-Call - ON
ID Mode - ID Search
Site Setup:
Site Type: Mot 800MHZ Standard (Type II)
Control Channel Only - ON
Trunk Frequencies:
Frequency LCN L/O Vol Adj Num Tag
859.38750 1 False 0 NONE
859.41250 2 False 0 NONE
860.38750 3 False 0 NONE
860.41250 4 False 0 NONE
The TGs I have been hearing so far (new ones) are:
45
79
20000
12466
13971
15055
16317
16820
16087
10364
47026
47034
47126
49034
Any idea what these are or where I can get information on TG ranges assignments etc? Thank you
System Setup:
Enable I-Call - ON
ID Mode - ID Search
Site Setup:
Trunk Frequencies:
45
79
20000
12466
13971
15055
16317
16820
16087
10364
47026
47034
47126
49034
