NYPD CW4 now P25
blaze
NYPD's first P25 system is now on the air. Citywide-4 is now all P25, to be (mostly) encrypted.
Expect other channels to follow, eventually.
ff026
ff026
I would not expect other channels to follow as there are not many p25 capable radios in the field.
one11sgt
CW 4 has had the ability to turn encryption on and off for a long time. It isnt used by 99% of the dept and isnt even programmed in the radios of patrol officers. It was initially for the brass to communicate before cell phones where prevalent. Its just another waste of a frequency just like Detective 1 and 2, SPIN, IAB and OCCB 1 and 2. None of these are used very much anymore since cell phones.
tbendick
Nyc
If i remember correctly they has p25 on citywide 4 in the past.
I am pretty sure if was Back early 2000's they had zone 1 going over cw4 in digital.
blaze
I believe the previous systems were a mix of analog and SecureNet; the new CW4, on the other hand is, all P25 (which is the first P25 infrastructure for NYPD).
ff026
ff026
No it's been P25 for a few years. It is not heavily used i.e. As stated it's not in patrol radios it's usually in executives radios many of which are not carrying a P25 radio.
blaze
I assure you you're wrong about that.
ff026
ff026
No I am not I have notes from early 2003 that list it as p25 it's been programmed in my XTS for that long. As far as p25 radios, ESU and some traffic units have the SSE transit now has the APX. That's about the lot of p25 radios. Captains and above carry the small Vertex which is not p25.
tbendick
Nyc
Early 2003 sounds about right. I was still working in lower Manhattan. I know it wasn't encryption I was hearing , because then I would never been able to hear zone 1 over cw4.
ff026
ff026
Ok. Is it a multicast from another division? Are you listening to it on something that can be decoded?
blaze
Doesn't seem to be. Mostly encrypted (AES) with the occasional "10-4" in the clear.
blaze
Yesterday (the 24th) was another busy day for CW4. Radio system testing in the morning, then some surveillance-type activity in the afternoon/evening, where they eventually went encrypted.
