Ocean County NOAA Freq.
Parts Unknown
#4
Ocean County NOAA Frequencies
The best one to use for the ocean monmouth area is 162.450. This transmitter is in Howell Township, Monmouth County. It is located at the Southard Fire House, on Rt. 9 north near Locust Rd. The other transmitters you are receiving are located nearly 45 miles away or better.
This transmitter provides excellent coverage for the greater Monmouth Ocean County area. Hope this helps. By the way as I type this(1648hrs 6-4-08) there is an active tornado watch in effect for the area.
Kevin
Formerly 69-1-32 MCPR
