odd antenna issue
project1
I set up an st-4 antenna this weekend and am having strange results. The antenna is at 25' but has less reception than my factory antenna. I put the same setup together for a family member 2 weeks ago with great results. Im no newbe to antennas , Ive been into radios and scanners for 20 years but this is a first for me. Any ideas??
DickH
Check continuity of the co-ax. There might be an open or a short.
LtDoc
Oklahoma
I have to think that the ST-4 should do better than a typical 'supplied' antenna. Not on all bands, naturally, but still still 'better'. Since it isn't doing that, then I have to think that something was missed or there was a goof in putting the thing together (I'm also sure you've thought the same thing). So, have you 'trouble-shot' the thing? Check the antenna, feed line, connectors, etc? How about 'opens' or 'shorts'? Besides the antenna, what else is different?
- 'Doc
(After all that if it doesn't "get better", it's gotta be the color of your socks.)
project1
yes the only thing different is the antenna and feedline. I checked for opens and shorts when I made the feedline. The rain set in on me here in East tx so I will work on it more when the weather clears. Its strange..
fineshot1
NJ USA (Republic of NJ)
Perhaps you now have front end overload on your scanner from very strong signal levels
from a close by transmitter(perhaps a paging station).
Have you tried your attenuator function to see it it helps the rx issue?
project1
I tried the attenuator with no detectable changes.. Im going to make a new feed line out of lmr 400 and see if that helps..
project1
multiple frequencies. Does that antenna have a matching network inside it?
LtDoc
Oklahoma
The way the thing is made, the relationship between the elements, is what amounts to a matching network. There shouldn't be an additional one.
- 'Doc
W2PMX
Fayetteville NC
Ir's just a disk, a vertical and a cone - there shouldn't be anything else (except a coax connector). If the antenna is shorted, it's because it's defective.
project1
Ok I will Take the antenna down tonight and check for a short at the feed point ..
project1
How can I test for a short on the antenna . If I test the so-239 connector it should show a short from inside to outside rite? If it shows an open that would indicate a problem . Am I correct in my thinking?
captclint
Mountaintop, PA
No, others have said there are no loading/matching coils, so it should be open.
jackj
NW Ohio
The ST-4 is a discone antenna. It doesn't have any matching network and a check with an ohmmeter should show an open between the center conductor and the shell of the SO-239. You should show continuity between the SO-239's center conductor and the disk/stinger portion of the antenna as well as continuity between the SO-239's shell and the cone portion.
project1
Ok.. Thanks . I will battle the weather and get it tested tonight.
wmbio
Cumberland, Md
You did not tell us what brand/model scanner you were connecting to the antenna? If it is a newer GRE/RS, Fineshot1 may be on to your problem with overload of the scanners front end by nearby FM/TV/PAGING transmitters.Many threads on the subject here.
Let us know how you make out with your testing?
Enjoy
Wmbio
project1
Ok I got it fixed. It was a bad bnc/so-239 adapter. i changed it out and everything is working fine. Thanks for all the help..
