odd behavior w/ SDR#
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
build is the current .1637 running on a high end dell laptop w/ windows 7
i am running the frequency scanner plugin from Vasili Beliakov - and something has gone a bit odd.
first, the squelch functionality of SDR# is supposed to be negated with Vasili's plug in --- that doesn't appear to be the case anymore on my build. compounding on this, the Red/Yellow squelch line settings in the freq scanner portion of the software don't seem to do anything anymore....
second, regardless of the step size I set up in the freq scanner plug in, SDR# is not searching in the correct frequency steps - for instance, i cannot seem to get the software to search in anything except 12.5khz steps in the VHF aircraft band.
thoughts?
rebuild the software (again)?
doug
BM82557
Berkeley Co WV
Are you using the latest version of his scanner plugin? The newest one was released 12/10/2017. It works fine for me.
batdude
Moderator
yep, figured it out.
the box under "BAND PLAN" was ticked to "AUTO UPDATE RADIO SETTINGS"
unchecked that box and things are back to normal.
doug
