Odd conventional systems behaviour Jag 700p
mitaux8030
Silent Key
Home
I had to rewrite a profile for a Jag 700p from scratch, and it all works as I expect except for an odd quirk in the conventional systems I have created.
When receiving on a conventional channel, the mute opens, but the little receive indicator 'antenna' symbol doesn't show up. Sometimes the audio will cut in and out rapidly and then the antenna symbol will flash... but that's the only time it lights up on a conventional system.
When scanning, the scan will stop and open mute on finding a signal, and will sometimes randomly resume scanning... but the display never shows the scanned channel, only the channel where scan was commenced from.
The conventional systems are as simple as can be, no PL / CTCSS, no DPL / DCS, no audible tone selective calling schemes either.
Any ideas what's wrong?
mitaux8030
Silent Key
Home
Solved: found that receiving conventional analog signals exhibits these problems when the channel & conventional system are programmed for digital voice.
Only problem is, some channels are genuinely needed for digital voice & analog. Not sure how to overcome that issue.
Radioman96p71
I have a similar setup but I programmed mine with 1 channel as strictly analog and the other as digital, so you have to manually switch between the two. Is this not what you want?
mitaux8030
Silent Key
Home
That might work... bit inefficient on memory though (yeah, old 8-bit assembly coder habits die hard).
Just for interests sake, I crammed the same profile into an LPE200, and found that it doesn't have the same 'problem' so I guess its Jaguar firmware related.
