TailGator911
Silent Key/KF4ANC
Using the cable that came with the scanner, have tried it both ways with a reboot, checked and unchecked
Gommert,
I am using ARC536PRO Version 2 Build 14. When I start Virtual Control for Logging via USB/COM3, the scanner audio becomes "choppy" and the scanner no longer stays on a talkgroup for the duration of the transmission plus the delay time. The scanner jumps around quickly to different talkgroups cutting off transmissions after about a second of elapsed time.
Once I disconnect the Virtual Control from USB/COM3, the scanner audio returns to normal and the scanner remains on the talkgroup for the duration of the transmission plus delay time.
Any idea what I might be doing wrong when I use Virtual Control on USB/COM3?
Thanks in advance!
Dave K4EET
