Oh Come on! Where's the Icons!
S
screamin72
Guest
#1
Well decided on ACARSD and it works but one problem is....planespotting.net is gone and the only photo source is airliners.net. How can I set ACARSD to download photos from airliners.net? planespotting.net is where acarsd used to get photos from. I have updated the databases in the menus. It's working with this for output:
NO AIRPLANE ICONS!:confused:
UPDATE:
Best advise for myself (and if anyone else does what I do) is stop panicking and look harder to solve a problem. I did some googling and it turned up a forum elsewhere that said its a plugin that changes the image server and now I have 4 to choose from. It's located in the extracted archive. All 3 need to be copied over to the c:\acard\plugins folder. Then load them in ACARSD menu and change server. It'll work as long as there is a matching image. Here is the real outcome:
The plug in is called "Use different picture database as iconserver V1.12b" Written by KJM acarsd@acarsd.org.
The jetphotos.com database crashes acarsd.
San Gabriel CA
#2
First, I'd say go with ACARSD1.70RC3 - there's a plugin for the "iconserver" where you can set which site to pull them from. There's maybe 6 servers you can use. The last time I ran it (which was awhile ago) I was using myaviation.net.
Here's the RC3 link:
http://www.acarsd.org/RC/
Oh and the same guys behind ACARSD moved on to libhomeradar.org. Their "winsend2" software has a built-in ACARS decoder: http://www.libhomeradar.org/contribution2.html
That was the last piece I played with before just sharing ACARS via PlanePlotter instead of actually monitoring it.
S
screamin72
Guest
#3
1.70 RC's
Oh and the same guys behind ACARSD moved on to libhomeradar.org. Their "winsend2" software has a built-in ACARS decoder: libhomeradar - easy collect aircraft information - Configuring contribution tool winsend2
Well I think I updated my post while you were typing yours. Got it working as it is. I will check out winsend and thanks for replying.:cool:
#5
Bumping an old thread here. I have 1.65 and can't get icon images to show up. How did you get it working? I can't tell from the original posts exactly what to do. Thanks.
