Ohio MARCs Pager
OHIO
Looking into getting a Ohio MARCs pager through Unication. What model do you guys recommend for me to monitor our paging channel, central FD dispatch talk channel, and our fire ground OPs? Would the G4 be an ok option for me? And these pagers "alert" when a certain tone is dispatched? Looking to use this for daily dispatching alerts, and FD monitoring.
Can you add other channels if I wanted to scan say OSP?
Thanks for any input.
MBECKNELL
Hamilton,Ohio
yes there are a whole lot of g4 pagers on the Marcs ip system. just make sure your county is doing tones over P25
Spitfire8520
I might be completely clueless! =)
Colorado
The G4 will work if you only need to monitor MARCS-IP and 700/800 MHz. If your local department does paging over VHF/UHF or has any fire ground channels on those bands, then you will need to consider a G5 with the appropriate secondary band needed for paging.
Something to keep in mind if you are planning to use it as a pager for alerting is that scanning other talkgroups will decrease the pager's ability to alert on a call. If you are in a position where you need the pager to alert you to respond, then it would be advisable to program your paging channels by themselves so that it will properly alert you of a call. Tones over P25 can work, but there have been a few reports on these forums of tones over P25 not working with their Unication pagers.
brucebuck1010
I use a G4 for monitoring Ohio MARCS-IP. It works very well for me monitoring LE, including OSP. I can't speak for FD or any thing with tones.
