OHIO MARCs PAGING TG
TFrank615
Springfield, Ohio
Anyone else in here from Ohio and their county get dispatched over a paging channel for the county? What’re the best rescinding setting to use with having multiple departments on one channel so it only records your department calls and not catching another call at the end of our own.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
If they're using the actual paging tones, they need to be nice and clean or the pager will not decode them properly.
Beyond that, there's a white paper on the Unication web page which explains a lot about the process, as well as how to set up the pager to respond only to the desired tones.
MBECKNELL
Hamilton,Ohio
i'm in ohio mine only catches the very first tone it alert on but don't alert for the other tones if there are double tones set off ie engine /medic
David_Oney
Former Unication Tech Support
Raceland, KY
This most likely is caused by the Delay N Timer. It was part of the original design during the Delay N timer not to alert on any other tones and specifically monitor the TGID so that none of the voice message is missed.
