The Ohio MARCs system is a simulcast system. Whistler scanners are horrible with the Ohio MARCs system wherever you live. Heck, I live in Cincinnati and my TRX-2 cannot even receive the new Northern Kentucky P25 Phase II system. I have had several GRE, RS and Whistler scanners and they are ALL horrible with the Ohio MARCs system. The best and only scanners that will work on the MARCs and the new NKY P25 systems are the Uniden SDS100 and SDS200. Both of those scanners are amazing with the P25 simulcast systems; I rarely get broken audio. The TRX-2 does receive DMR and NXDN very well and of course conventional FM. My last remaining Whistler scanner is now only used to receive DMR, NXDN, Aircraft AM and conventional FM. I wish Whistler would come out with a new SDR based scanner like Uniden, but it appears that they cancelled the project. Too bad.
Ohio MARCS is not a simulcast system. Some individual sites (mostly in metropolitan areas including the Cincinnati-Dayton-Troy metroplex) are simulcast, but in Wapakoneta the only site is a stand-alone as are most MARCS sites, which Whistler scanners should work well on.
All sites are simulcast. For example, if any police agency is using the Pursuit TG, it is simulcasted throughout the entire state. Your county may only have one site, but that does not mean your county's traffic is not being simulcasted in an adjacent county. If the sites are spread far enough, you may not have the simulcast decoding issue causing garbled audio. Good for you. However you will never or almost never have issues with the SDS100 or SDS200. Why take a chance? In Ohio, the best scanner for MARCS is the SDS models from Uniden.
Also not correct. The Pursuit talkgroups, like all other talkgroups, will only appear on sites where someone on the talkgroup in use is affiliated to that specific site. Simulcast refers to the same transmission being broadcast from multiple towers on the same frequency at the same time; those towers are part of a single site. When broadcast from multiple sites on different frequencies (the majority of MARCS) it's called Multicast, and that won't cause the interference issue you get with Simulcast.
Sorry you've had issues with Whistler scanners, but your county
does use a simulcast site and making a major generalization as you have is unfair and misleading. I'm south of Columbus and my TRX-1 and PSR-500 work just fine where I live, surrounded by stand-alone (non-simulcast) sites. My scanner feed uses a PSR-600 and it's crystal clear.
To the OP: Check the programming of your radio to make sure you're only monitoring the Wapak site; it's possible your radio may have more than one site programmed and can't receive the more distant site very well. If you're right in Wapak, you should be able to receive that site quite well. It's also possible that the garbled transmissions you're hearing are the person on the other end being in an area of sketchy coverage and
they are the one who is actually garbled; I hear that at home from time to time, usually when someone is indoors in a pretty rural area.
