OHP Pursuit
dbestfirefighter
KRCE
OHP in pursuit starting at 1-40 and Garthbrooks, in Yukon, Trooper gets out to make contact with suspect. Suspect takes off.
dbestfirefighter
KRCE
Suspect on 39th going WB, OHP units requesting assistance from Warr Acres, and Bethany.
kc2iyh
Booneville, AR
What was the reason for the pursuit and why would OCPD deny assistance and the provide unsolicited assistance later? I guess if an OCPD units needs OHP they won't forget this. Is the LT a political appointee?
HogDriver
Oklahoma City
Watch the news tonight...
I guess since the chase was going thru city streets and OHP already was involved, they decided to let OHP have it to limit the number of cars involved in the chase.
dstew67
Oklahoma
That's exactly right. New pursuit engagement rules came into play almost two years ago.
The first thing that happens is, a managing supervisor is advised and put directly in charge. That supervisor starts asking a bunch of questions about traffic, charges, road conditions, etc. Air One is then called. Once Air One gets on scene, ALL ground units back off.
OR
Once the pursuit travels onto an interstate, OHP gets involved and almost all OCPD units are told to back off and go back into service.
dstew67
Oklahoma
...my point is, once these new rules of engagement were put into place, supervisors have strick rules they have to follow. Those rules did not allow for OCPD to assist OHP in the actual pursuit. They did however, assist with stop sticks and with paralleling the pursuit to assist on the ground if/when the pursuit ended. So, it wasn't that he was thumbing his nose at OHP. He was assisting in ways that his rules allowed for him to assist.
