Old school inversion de-scrambling device
SABER3
Saber3
I’m looking for an old school inversion scrambling decoder. I had one decade ago but I have a use for one now. They were even offered by kits in the late 70’s to mid 80’s. Any ideas? TY for the 411
If you live in the U.S., it is possibly illegal to decrypt inverted speech scrambling on radio communications. That said, try these...
kc2asb
NYC Area
There used to be kits from Ramsey Electronics (?) and ready-built devices that you could buy to de-scramble voice inversion, but I believe they became illegal to manufacture and sell after the ECPA was passed into law. Check on Ebay - you might find one of those old de-scrambler kits or devices from back in the day.
Wasn't Digital Voice Protection (DVP) and early form of encryption?
IC-R20
LoBand Nation
Get a Cheap Chinese Radio with a scrambler setting and just turn it on.
I got a Baofeng BF888s in 2014 and was lucky enough to get one with the working scrambler setting. When one of the local taxi companies on UHF Conventional started using scrambling I programmed their frequency into multiple channels with each of the different scrambling patterns and just flipped through them until I found which one worked.
Also you can buy AOR communications receivers from Asia or Canada on eBay that will have a descrambler unit, like the DV10 for example. I got a Alinco DJ-X30e (Europe version) on eBay in 2023 that also has a descrambler and is nice and compact.
But, since most radios will use a common set of standardized scramble patterns its not like an encryption key on p25 so the cheapest easiest way is the buy a cheap commercial radio with scrambler and turning it on, odds are most times you’ll be able to hear whatever they’re doing as long as it covers the same RF frequency.
If anyone thinks voice inversion scrambling is secure, then they deserve it. You can buy nearly any Kenwood radio and it has the inversion frequencies already loaded, just program a channel with each one of the 16(!) codes and try them until you decode it properly.
If your security relies on a 1 in 16 chance of someone guessing the code, then you have zero security.
kc2asb
NYC Area
better off safe than in jail...
gotta ask yourself one question, is it worth it ?
Even though the ECPA made these voice inversion de-scramblers illegal, anyone that owns and uses one has little chance of getting caught. It's much like listening to analog cellphones back in the day, which was also illegal under the ECPA. It's practically unenforceable
BinaryMode
Banned
2600 dialtone blvd
Here ya go. Coded it myself with the help of AI. Do let me know if it works for you. I have a couple scripts here and I'm not sure if this is the right one. The other was a BFO. I have used this with what I think is a towing company. LOL
Now the nerdy part to those that know. Since this script is nothing but HTML, CSS and JavaScript it can be compiled into Electron (not recommended) or Tauri or Flutter. Which means the code can be compiled to a phone App.
I'll call it unlicense. Unlicense Yourself: Set Your Code Free
  • Inversion.zip
dlwtrunked
Google AI says 1996 instead of the ECPA date --as usual AI is wrong. If you slightly reword the question, it will tell you that it is not illegal--again AI is wrong. Hard to get AI to give you a right answer to almost anything. Now the easy way is to download the software for a PC that will de-scramble the audio.
Here is a related interesting old document. https://www.govinfo.gov/content/pkg...VPUB-C13-38e6dc21a1cc9e76d55d0dd8391a8559.pdf
kc2asb
NYC Area
Thanks for posting that doc. I scroll right past Google AI results. It's worthless and they are trying to force it on to people.
IC-R20
LoBand Nation
There’s a snippet I put into uBlock plug-in to remove it. Funnily enough after I did that it doesn’t show on my iPad either now. I also added another to block Amazon’s.
