Old VCOM (CYYZ) control channel/activity???
02blackss
Brampton, Ontario
I was doing my usual scanning of CBSA this evening, and I thought for the heck of it I would scan the old VCOM system for awhile...
I noticed the control channel was buzzing away, and I also caught some digitized conversation..I assume it was encrypted..
I thought they were on a completely new system and the old system would be de-activated/not used?
Anyone know?
Jason
Forts
Ontario, Canada
Many times when new systems come online there are stragglers that are slow to get switched over, or sometimes old radios get re-purposed for another job before the system gets shut down. I monitored the new system last night for a little bit and there wasn't a whole lot of activity on there either.
mikewazowski
Staff member
Central Ontario
Jason, which system are you referring to?
VCOM is the name for the Region of Peel's 3600baud system. I believe there are still many users left on the system including all the Fire Departments within the Region. I don't believe they've switched to the new system yet.
When the GTAA were using the Peel system they referred to the channels as VCOM since that was the name of the system.
02blackss
Brampton, Ontario
Hi Mike, So yes, I am referring to the GTAA portion of the VCOM system. There was a thread on here some time ago stating that the GTAA was going to a new system and it was 100% encrypted. Since then, I have not heard a peep out of it. And just last night I was monitoring it and I heard some digitized voice...(This was on my analogue BCT15X)..
Jason
mikewazowski
Staff member
Central Ontario
Than you've got me totally confused. GTAA was using talkgroups on Peel's VCOM system. Nothing on VCOM has been turned down and GTAA didn't have any "portion" of VCOM.
02blackss
Brampton, Ontario
02blackss
Brampton, Ontario
I just got this information from another forum member...
The system that Lakeshore Communications is providing is not to be confused with the new Peel region P25 Phase 2 system. Although they are both interoperable. The new Lakeshore system is to replace the old 900mhz trunked Harmony Iden system that was installed for GTAA VCOM.
Jason
mikewazowski
Staff member
Central Ontario
Jason
VCOM is the old Peel system. It has nothing to do with the 900MHz Harmony system.
Google "Peel" and "VCOM" and you'll see that the name for the old Peel system was VCOM.
I assume it's the name for the new Peel system as well.
GTAA left the Peel VCOM system and moved to a new P25 system that was installed at the airport just for them.
02blackss
Brampton, Ontario
Ok, I take it back...at 7:21 there was an alert tone being sounded on VCOM6, then a womans voice about a cleanup at terminal 1.
I did not catch it all, so...it appears as if the old system is active to some degree?
Anyone have any info on this?
Jason
mciupa
DB Administrator
Moderator
Just heard a medical call on VCOM6 around 7pm, so it's still alive.
