Older Radio shack USB cable...
radsmachine
Mississippi
I've just purchased a whistler 1040. Along with the arc500 software. I have an older usb cable that I used to use to program a PRO2055 scanner. Will it work with the Whistler scanner as well? TIA...
Rich.N5IDK
radsmachine
Mississippi
radsmachine
Mississippi
Well, the question is moot. The radio came with a cable. Now if I could just figure out how to program the MSWIN into it...
tvengr
Well Known Member
Baltimore County, MD
The database shows that you should be able to receive the sheriff dispatch and car to car talkgroups on MSWIN. They are the only P25 Phase 1 talkgroups in Jasper County. Everything else is Phase 2. Bay Springs PD is P25 Phase 2. The WS1040 is capable of decoding P25 Phase 1 only. D in the Mode column is Phase 1. T (TDMA) is Phase 2. Here is a sample of the talkgroups for Jasper County.
43075a843T31-JC FIRE DISPCounty Fire - DispatchFire Dispatch
43009a801D31-JCSO DISPSheriff - DispatchLaw Dispatch
43011a803D31-JCSO C2CSheriff - Car to CarLaw Talk
43040a820T31-B SPGS PD DISBay Springs Police - DispatchLaw Dispatch
43041a821T31-B SPGS PD C2CBay Springs Police - Car to CarLaw Talk
you will need to use the Bay Springs site in Smith County. The 2 sites in Jasper County are most likely out of range. The MSWIN talkgroups in Smith County are all Phase 1 and can be received by your scanner. If you would like, I can create an ARC500 file for your local area.
tvengr
Well Known Member
Here is an ARC500 file for Jasper and Smith Counties to get you started. Save the attached zipped file to your computer and extract. Open the extracted file with ARC500 and Upload to Scanner. Scan lists as follows:
SCAN LISTS:
1. Jasper Co Trunk
2. Smith Co Trunk
3. Jasper Co Conv
4. Smith Co Conv
  • Jasper Co MS GR5.zip
radsmachine
Mississippi
Could someone make me an arc500 file for MSWIN for jasper, smith, forrest, covington, newton and jones counties with all of the conventional freqs as well? I'm willing to pay for the time. Also the mhp if I can hear any of them
