One antenna, Multi Scanners
#1
I am looking to run several scanners from one antenna and feed line. I am looking for suggestions on isolation between the units to prevent them from desensing one another. Hoping for a homebrew project as opposed to purchasing something if at all possible.
Ryan
tonsoffun
Senior Moderator
Moderator
Central Ontario
#3
