Has anyone programmed in a Trunked system to their SDS100/200, that is programmed like every other favourite, that when you look at the QuickKey tab you see the HPD file number … and when you verify in the the folder on your SD card that the HPD file is in there … that just won’t show up in the scanner?
I have actually deleted the HPD file, rewritten it, and the same damn issue persists. Everything else is on the SD card and appears on the SDS radio, but this one just won’t.
