Oneida County VHF P25 Trunking?
Central/Upstate NY
Interesting that it might be the NYS Watch Center and those IDs. Both 8429065 and 8429066 have been seen on the Albany County system and are OFPC units from what I can tell. I have also heard 900 series units testing on the Albany County system with the "Watch Center". Seems like they are interfacing with regional system to create statewide radio coverage back the the Watch Center in Albany. Believe some one in OFPC indicated to me a while ago they were testing with units in Buffalo as well.
8429096 was calling as "OEM portable 907"
Watch Center was answering back "on a console, in Albany"
Oneida County, NY
For those using Uniden scanners - do you 'avoid' the other CNYICC counties listed as simulcast (i.e. Cayuga Simulcast, Madison Simulcast, Onondaga Simulcast, and Oswego Simulcast)? Does it matter?
BTW - My latest station upgrade really improved the reception of the Oneida County P25 system. I moved to the SDS200 and also upgraded my antenna system to the MP Antenna 08-ANT-0861. The quality of the signals is much better.
GTR8000
Troublemaker
BEE00
It only matters to your specific situation, not what anyone else is doing. If you are unable to receive a strong, reliable signal from any of those other simulcast cells, then there is no point in scanning them.
Utica, NY
FWIW: I just acquired an BCD996P2. I live in downtown Utica. Using the stock antenna indoors, i have clear audio, and a 0 Error rate. I hook up to the external antenna 80 feet up, and its all garbled due to LSM. Yes i have all other counties locked out as well. Im waiting on Whistlers new scanner to be released then ill see if that fixes LSM for the area.
Thunderknight
Bletchley Park
If you only want to hear Oneida TGs then ignore/don’t scan the other counties. Scanning them will just cause you to miss Oneida traffic as your scanner checks those control channels for TGs that won’t be there anyway.
Oneida County, NY
Thanks to those who responded to my recent post. I believe that I have resolved my confusing reception issues with a new set of favorites lists. The confusion started when I was hearing transmissions from other counties on the Oneida County simulcast system. I would also hear Onondaga County on the Madison County P25 system. Yah, I was confused.
The fix was to 'avoid' the other simulcast systems and avoid talk groups from the other CNYICC counties. I did this across all the lists so that each is now segregated for the county of interest. My favorites are now organized as follows: Cayuga County, Lewis County, Madison County, Oneida County, Onondaga County, and Oswego County. I also have favorites for non-P25 systems: NYSP (Troop D), NY Thruway , Aviation, Upstate NY Amateur Repeaters, and various Utilities
The Oneida County P25 Phase 2 system is sometimes a challenge because of the terrain between me and the Rome NY tower. Since I live in the Northwest part of Oneida County, I have good signals from Oswego, Onondaga, Madison, and sometimes Lewis County. Question – do all the Oneida County talkgroups get simulcasted to the neighboring county CNYICC P25 systems? If so, this would be my fix for my marginal reception issues for Oneida County.
nacsr
Rome,NY
Not sure where you are. I'm in Lee and have lousy reception. I have the TRX 1
and the UNIDEN436. I have high error rates 20 - 30 on an outside antenna. Have tweaked settings with no luck. As you said, I can receive all the surrounding Counties if I want too. I can receive digital fine if I'm in Rome. So I mostly keep the Phase II locked out. I have an expensive analog scanner.
Thunderknight
Bletchley Park
No, generally each counties TG is specific to that county simulcast. There are a few TGs that are carried in a neighboring county for coverage improvement or mutual aid. And there are a few that are consortium wide.
But, overall, if you want to hear Oneida TGs you must scan the Oneida simulcast.
I’d be willing to bet that reception will most likely get better in the coming months. There will be some talkgroups roamed from system to system, but there is a caution on limits due to capacity. An Oneida TDMA talkgroup roamed into Madison, for example, is roamed as FDMA to be compatible with Madison’s system.
Oneida County, NY
Thanks for your insight. I believe that my favorites lists are sorted out now and I hear the county traffic where it belongs. Now that I have played around with the SDS200 this weekend, I can't believe how much better it handles the Oneida County P25 system. The receiver in this beast is incredible. I love it that I can now hear Rome and Utica traffic up here in Camden.
Oneida County, NY
nacsr - I am up the road in Camden. My biggest reception issues are the terrain between me and the Rome tower. As mentioned in my previous post, I have upgraded my antenna and now the scanner. The antenna was a big improvement, but reception of the Oneida County P25 system was still marginal. Since the addition of the SDS200, the reception has greatly improved. It isn't perfect as I still hear some digital artifacts, but these are now minimal. Overall, I appreciate that I can now hear the P25 system for county I live in!
nacsr
Rome,NY
I'll have to check out that antenna. Was in Rome yesterday with my 436 at Price Chopper and had great reception with 0 errors.I talked to an OC Deputy and he said they are having issues and work is ongoing.
Wait until they are legitimately using it for a while then ask. I’m sure there will be complaints, there are going to be tweaks; And there will be those who are unhappy with change, but complaining to citizens about a digital system that is not yet in countywide use is premature.
nacsr
Rome,NY
To be clear, he wasn't complaining to me. I merely asked a question, told him why I was asking and he answered it. Nothing more.
RCjim
New York
Hi is anyone using a whistler TRX-1 to monitor this simulcast system, I would like to know if there are setting I can change for better reception? I'm east of Utica and get no reception until I'm in Utica.
Anyone have settings they would share would be appreciated. DAC, ADC, DSP, Threshold Hi and Low, and anything else that helps improve signal strength on the P25 PII system. Thank you!
Clarity of analog conventional MRD still sucks. It has gotten slightly better...but it still sucks. Shame nobody seems to care due to the focus on making the P25 system work. If this degraded signal on the county's conventional analog is going to be a permanent side effect of simulcasting and/or integration with the P25 system, I can't imagine anyone expected it. At least I hope not.
Oneida County, NY
Are you saying the 155.430 Oneida County Sheriff audio is crap? If so, I am not experiencing this issue. The audio on this conventional channel is crystal clear to me. When I switch over to the P25 talk group [65035], I pick up some of the digital artifacts, but the audio is still tolerable.
