OneVoice MotoTRBO Connect Plus Net 171
cg
Connecticut
Vermont Sites are on the air, 71-77. I only logged the CC for 5 of them when I was out chasing radio signals yesterday but they up and running
73 - cc 451.2125
74 - cc 454.5750
75 - cc 451.6750
76 - cc 451.3000
77 - cc 454.6000
Neighbor listings show 71 & 72 are in service
chris
W2SJW
Senior Member
Northwest NJ
I just looked at some new documentation on Connect Plus & see that the max number of sites is 250. I could have sworn I read somewhere that it was 70 (or something near there).
Damn, this system has the possibility to get HUGE!
RayAir
From the Connect Plus System Planner:
Each site can support a maximum of 15 repeaters.
The maximum # of traffic slots on a system is 770.
Ex- On a 70 site system an average of 6 repeaters per site are supported.
On a maximum size system (250 sites), the average # of repeaters per site should not exceed 2.
These limits are not enforced, but it is strongly recommended not to go above it.
pro92b
Mutated Member
The sites I can receive typically have fewer than half their assigned frequencies active. Many sites have 454 MHz allocations but there is very little activity noted here on 454 MHz. The same 454 MHz frequencies are replicated on sites that are geographically close to each other. Is there some way the system coordinates usage of these duplicated frequencies among sites or are they just not used much?
cg
Connecticut
454 frequencies were auctioned off and the winners get the block of spectrum in a large geographic area. The benefit is you are not limited to have one frequency at a specific site.
I suspect the reason they are in each site in this system is to be able to turn on a couple frequencies to accommodate a large new client or event without having to do a bunch of work other than putting a couple additional repeaters at the site and activating the additional channels in the programming.
chris
pro92b
Mutated Member
73 - cc 451.2125
74 - cc 454.5750
75 - cc 451.6750
76 - cc 451.3000
77 - cc 454.6000
chris
From FCC records site 73 appears to be in Manchester, WQVJ903. I can just receive the control channel here and neighbors are 71 72 74 75 77. Color code is 1 and the control channel 451.2125 is LCN 01. There is one other frequency active in the site but I have not found it yet.
Site 75 is probably in Bennington and site 76 appears to be in Hinsdale, NH.
Code:
Central Vermont Communications, Inc.
Call Sign       Location                         Frequencies
WPTF761 Mt Equinox, Manchester, VT       461.6125 461.9625 464.8125
WPTF761 Mt Anthony, Bennington, VT       463.4125
WPTF761 Mt Ascutney, Windsor, VT         461.8375 463.8375
WPTF761 Hannum Hill, Putney, VT          461.7375 463.4375
WQVJ903 Mt Equinox, Manchester, VT       451.2125 452.5750 452.6625
WQVJ903 Mt Ascutney, Windsor, VT         451.2250 451.4250 452.5750
WQWE675 Mt Anthony, Bennington, VT       451.6750 452.4500
WQWE675 Wantastiquet Mt Rd, Hinsdale, NH 451.3000 452.2125
WQWV715 Mt Mansfield, Stowe, VT          451.5250 452.1000
WQWV715 Brownell Mt, Williston, VT       452.5500 452.7375 462.2000
WQWZ437 Mt Snow, Wilmington, VT          452.5500
WQWZ437 Stratton Mt, Stratton, VT        463.2125 463.4125
WQXY989 Grandpa's Knob, W. Rutland, VT   451.6125 452.2625
WQXY989 Pine Hill, Bennington, VT        451.2625 463.4125
WQXY989 Mt Ascutney, Windsor, VT         452.2625 452.8375
WQXY989 Mt Equinox, Manchester, VT       452.4125
WQXY989 Pico Peak, Sherburne, VT         452.7625 452.8875
WQXY989 Hannum Hill, Putney, VT          451.6125
WQYB596 Rogers Hill, West Newbury, VT    451.0375 451.6375 452.8625
cg
Connecticut
The locations were base on the same thing you did with the licenses. Site 73 I got the CC but did not get the LCN.
Here is the untested LCN order that I "received":
Site 71 - ?? VT (1) 454.20000, (2) 454.40000, (3) 454.52500 (4) 454.65000
Site 72 - Windsor, VT (1) 451.22500, (2) 451.42500, (3)452.57500
Site 73 - Manchester, VT (?) 451.21250
Site 74 - ??, VT (1) 454.05000, (2) 454.15000, (3) 454.30000, (4) 454.57500
Site 75 - Bennington, VT (1) 451.67500, (2) 452.45000
Site 76 - Hinsdale, NH (1) 452.21250, (2) 451.30000
Site 77 - Stratton, VT (1) 454.60000, (2) 463.21250
chris
pro92b
Mutated Member
Thanks for the update Chris, I have added the info to my system spreadsheet. Site 73 is weak here and hard to decode. I don't know if I can find the other active channel from here or not. The site does not seem to be very active but that could just be my poor reception.
pro92b
Mutated Member
Captured by DSD+ after overnight monitoring, site 73 LCN 02 is 452.6625.
D
DaveNF2G
Guest
"New" talkgroups via Site 25
500220 single transmission
500283 school buses in MA
500343 discussion of "elevations". This is one higher than the TGs listed for NYC DEP, so it could be theirs. The mobile unit signed off with "Signal 7" which is a code used by NYSE&G.
500500 Saugerties school buses
500520 school buses. Mentioned Riverdale Country School (Bronx).
500830 medical transportation in Rockland County
GTR8000
NY/NJ Database Guy
BEE00
500220 has already been identified as Minnewaska State Park in Ulster County. It's been in the database since last month.
I don't see a submission for the rest of the talkgroups you've found. Were you planning on making one?
GTR8000
NY/NJ Database Guy
BEE00
They are not sufficiently identified to meet database standards.
Not true.
Please refer to the Database Administrator Handbook v1.8, Section 6.1 on page 8:
Entries in the database do not necessarily have to be specific with respect to their identification (although this is ideal) but they may not be completely unspecified. For example, a talkgroup on a business trunked system is considered “identified” if it is known to be “private security” or “ambulance service” (for example) even though the exact name of the business may remain unknown.
Four of the talkgroups you've observed meet the standards for inclusion in the database:
500283 School Buses (Massachusetts)
500500 School Buses (Saugerties)
500200 School Buses (Bronx)
500830 Medical Transport (Rockland)
EDIT: I've gone ahead and added these four to the system.
D
DaveNF2G
Guest
Thanks for the clarification and the database submission. Now I'll be better informed and my research will be more useful. :)
K2KOH
Putnam County, NY
Dave, apparently DEP uses Signal 7 as well, I've copied it on the DEP Police talkgroup. Interesting listening to them...I receive Eastview and Ashokan, but occassionally the system links together and I catch Hillview, but the link has its own talkgroup. Interesting.
W2SJW
Senior Member
Northwest NJ
That info should be in the database already (and has been for months).
Sent from my Galaxy S6 via Tapatalk 6
n2nov
Staten Island, NYC
Thanks. I found the wiki with color code and talkgroups, but the frequencies are less than each site in the database and there are some mixing between sites. Which is more up to date, the wiki or the database?
