Onondaga County assistance
N2RGU
Syracuse, NY
Hi ya, just registered yesterday, and I'm using the Home Patrol II that I picked up. I imported the file into my favorites, made sure both the monitor and download were on. I am receiving signals via the antenna, but nothing is showing up and I'm not hearing anything. I think I'm missing a step somewhere. Onondaga County is using P25 Phase 2 so this scanner should be picking them up. Any suggestions would be great!
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Welcome to the RR forums. You're likely facing simulcast distortion depending on where you are in relation to two or more towers on the Onondaga Simulcast. Feel free to try the multipath mitigation steps in the wiki linked below but ultimately you'd be better off with a Uniden SDS100 or SDS200 to track simulcast systems.
  • Like
Reactions: wtp
k2hz
Rochester, NY
Simulcast will definitely be a major issue for that scanner. One thing to check in your programming is to only monitor the Onondaga site and not try to scan the entire CNYICC system.
scan1806
onondaga cty,New York
IM in bville and will be glad to help you out
scan1806
Im in bville and will help you out get back to me
tvengr
Well Known Member
Baltimore County, MD
Give this file a try. Save the attached zipped file to your computer and extract. Go the File tab in HomePatrol Sentinel and click on Import from hpe file. Click on New Favorites List and name it: Onondaga Co NY Click on OK. In the Downloads folder, open the extracted file. It will appear as a favorites list in Sentinel.
  • Onondaga Co NY HP.zip
N2RGU
Syracuse, NY
Thank you! Will give it a go!
