Op25 Boatbod sample rate question
dave3825
New York
#1
Op25 is working fine on the system and audio sounds great. However, I did notice an error in start up after launching,
./rx.py --args 'rtl' -f 852.7375e6 -g 65 -o 17e3 -N 'LNA:35' -V -T suff_site_4_800.tsv -2 -U -l http:127.0.0.1:8080
The error,
supported sample rates 250000-2560000 step 24000
Invalid sample rate: 320000 Hz
I looked thru the readme and it says
-S SAMPLE_RATE, --sample-rate=SAMPLE_RATE
source samp rate
I do not have -S in my line. Does it default to 320000? Do I need to worry about it? I am using a nooelec smart
boatbod
Talbot Co, MD
#2
The error,
source samp rate
The default does appear to be 320,000 if the -S parameter is missing. Valid sample rates are usually multiples of 9600. I can tweak the default so it's valid, not that it'll change much other than make the error go away.
Thanks for the heads up.
