I am using Raspian-stretch with Desktop
Download Raspbian for Raspberry Pi
Below are some down and dirty notes but this should get you up to the point where op25 is installed and just needs to be configured
Using SD Card Formatter - Format SD Card
Using Win32DiskImager - Write Raspian image to card
Insert card into Pi, Plug Pi into keyboard/Monitor
Power on Pi
run updates
open a new terminal window
(if you want to force the audio to go thru the 3.5mm jack for local monitoring)
run sudo raspi-config
scroll to 7 - Advanced Options --> A4 Audio and select force 3.5mm
reboot the pi
--Install OP25--
cd ~
git clone
boatbod/op25 op25
cd ~/op25
./install.sh (this takes awhile on the Pi)
--Install gnuplot
sudo apt-get install gnuplot-x11
See if you can get to this point and then the next step is to configure the trunk.tsv file located in /op25/op25/gr-op25_repeater/apps. boatbod made some updates using LiquidAudio which in my opinion was easier to get going.
