ok i made the conf files read like above. i rebooted and it shows online on broadcastify but i never can hit play. then it goes offline.
heres the log from the stderr.2 file. on the server info i deleted my password and such.
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Invalid sample rate: 57600 Hz
Using two-stage decimator for speed=1024000, decim=16/2 if1=64000 if2=32000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail:
pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio:
pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1], do_nocrypt[1]
Reading whitelist file
added talkgroup 38500 from randolph.wlist
added talkgroup 38501 from randolph.wlist
added talkgroup 38502 from randolph.wlist
added talkgroup 38503 from randolph.wlist
added talkgroup 38504 from randolph.wlist
added talkgroup 38505 from randolph.wlist
added talkgroup 38506 from randolph.wlist
added talkgroup 38507 from randolph.wlist
added talkgroup 38508 from randolph.wlist
added talkgroup 38509 from randolph.wlist
added talkgroup 38510 from randolph.wlist
added talkgroup 38512 from randolph.wlist
added talkgroup 38513 from randolph.wlist
added talkgroup 38514 from randolph.wlist
added talkgroup 38517 from randolph.wlist
added talkgroup 38519 from randolph.wlist
added talkgroup 38523 from randolph.wlist
added talkgroup 38536 from randolph.wlist
added talkgroup 38556 from randolph.wlist
added talkgroup 38577 from randolph.wlist
added talkgroup 38586 from randolph.wlist
streaming server url="http://audio9.broadcastify.com:80/?????????????.m3u"
1576197542.853369 control channel timeout
1576197543.363234 Reconfiguring NAC from 0x000 to 0x1f0
1576197550.805032 voice update: tg(38506), freq(771731250), slot(-), prio(3)
1576197553.727558 voice update: tg(38506), freq(771731250), slot(-), prio(3)
1576197554.891575 voice update: tg(38506), freq(771731250), slot(-), prio(3)
1576197557.461933 voice update: tg(38506), freq(771731250), slot(-), prio(3)
1576198028.588546 control channel timeout
1576198028.590099 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198028.695271 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198028.817264 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198029.337605 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198031.764380 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198032.796786 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198046.088994 meta_server::send_metadata(): metadata update error: 400
1576198046.551404 meta_server::send_metadata(): metadata update error: 400
1576198046.818815 meta_server::send_metadata(): metadata update error: 400
1576198047.122445 meta_server::send_metadata(): metadata update error: 400
1576198048.669059 voice update: tg(38509), freq(770068750), slot(-), prio(3)
1576198052.606978 meta_server::send_metadata(): metadata update error: 400
1576198052.629462 voice update: tg(38509), freq(770068750), slot(-), prio(3)
1576198053.528385 voice update: tg(38509), freq(770068750), slot(-), prio(3)
1576198056.858149 voice update: tg(38509), freq(770068750), slot(-), prio(3)
1576198057.872598 voice update: tg(38509), freq(770068750), slot(-), prio(3)
1576198060.318985 voice update: tg(38504), freq(771731250), slot(-), prio(3)
1576198063.147169 voice update: tg(38504), freq(771731250), slot(-), prio(3)
1576198064.027311 voice update: tg(38504), freq(771731250), slot(-), prio(3)
1576198065.556301 voice update: tg(38504), freq(771731250), slot(-), prio(3)
1576198066.578261 voice update: tg(38504), freq(771731250), slot(-), prio(3)
1576198086.317768 meta_server::send_metadata(): metadata update error: 400
1576198091.552062 voice update: tg(38506), freq(770356250), slot(-), prio(3)
1576198095.131188 voice update: tg(38506), freq(770356250), slot(-), prio(3)
1576198096.152658 voice update: tg(38506), freq(770356250), slot(-), prio(3)
1576198099.219201 voice update: tg(38506), freq(770356250), slot(-), prio(3)
1576198100.240429 voice update: tg(38506), freq(770356250), slot(-), prio(3)
1576198161.834766 voice update: tg(38509), freq(772756250), slot(-), prio(3)
1576198164.388362 voice update: tg(38509), freq(772756250), slot(-), prio(3)
1576198165.394636 voice update: tg(38509), freq(772756250), slot(-), prio(3)
1576198167.837506 voice update: tg(38509), freq(771731250), slot(-), prio(3)
1576198170.645560 voice update: tg(38509), freq(771731250), slot(-), prio(3)
1576198171.668362 voice update: tg(38509), freq(771731250), slot(-), prio(3)
1576198178.998645 meta_server::send_metadata(): metadata update error: 400
1576198185.050801 meta_server::send_metadata(): metadata update error: 400
1576198277.171024 voice update: tg(38513), freq(771581250), slot(-), prio(3)
1576198280.639167 voice update: tg(38513), freq(771581250), slot(-), prio(3)
1576198281.656539 voice update: tg(38513), freq(771581250), slot(-), prio(3)
1576198282.542866 voice update: tg(38513), freq(771581250), slot(-), prio(3)
1576198286.126095 voice update: tg(38513), freq(771581250), slot(-), prio(3)
1576198287.036168 voice update: tg(38513), freq(771581250), slot(-), prio(3)
1576198289.480173 voice update: tg(38506), freq(770068750), slot(-), prio(3)
1576198291.768503 voice update: tg(38506), freq(770068750), slot(-), prio(3)
1576198292.673382 voice update: tg(38506), freq(770068750), slot(-), prio(3)
1576198295.227001 voice update: tg(38513), freq(772756250), slot(-), prio(3)
1576198297.531134 voice update: tg(38513), freq(772756250), slot(-), prio(3)
1576198298.802289 voice update: tg(38513), freq(772756250), slot(-), prio(3)
1576198301.111237 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198304.180352 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198307.141896 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198309.086875 control channel timeout
1576198309.088368 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198309.900328 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198313.292249 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198314.810527 voice update: tg(38513), freq(770356250), slot(-), prio(3)
1576198321.360707 meta_server::send_metadata(): metadata update error: 400
1576198323.278771 voice update: tg(38513), freq(771731250), slot(-), prio(3)
1576198327.504282 voice update: tg(38513), freq(771731250), slot(-), prio(3)
1576198329.918645 meta_server::send_metadata(): metadata update error: 400
1576198330.702511 voice update: tg(38513), freq(771731250), slot(-), prio(3)
1576198331.729600 voice update: tg(38513), freq(771731250), slot(-), prio(3)
1576198334.293125 meta_server::send_metadata(): metadata update error: 400
1576198351.501996 meta_server::send_metadata(): metadata update error: 400
